LSx v8 swap?
Before you start bashing me or turning this into a anti v8 or "why not just turbo it?" thread, I just wanted to see if it has been done before. I having 400-500lbs of tq and 400-500whp from 3-6,000rpms would be fun in a lightweight FR setup.
I was wondering if you S2k owners have run into any s2000 that had a v8 swap. On the road or just on the internet. I've seen the 2JZ done before.
I know that it's easy to do in a miata & rx7.... I would imagine it even being easier the the much larger s2000 engine bay.
It has been done, and its really common in E36 M3's. The issue in the S2k is moving it far enough back to maintain weight balance. If I remember right the firewall has to be modified to keep the engine behind the front wheels, it results in the shifter being an extra 5-7" back. It's a great idea but it doesn't work so well in the S2k.
Check out http://www.vorshlag.com/ they make a great kit for the E36 BMWs.
It's been done.
There's one running around here in florida. Seen it go mid 10's in the 1/4.
Yup it's been done in a S2K like the others have said!
http://videos.streetfire.net/videos/...3&t=Ls1%20swap
check out the vids
Swap has been done in these cars and more:
240sx
270Z
Miata's
Evo's
WRX
RX7
BMW's
300ZX
3rd gen Camaro's
Honda Civic - you guys should know the Civette
Old School Chevy's
Skyline's
Supra's
check out the vids
240sx
270Z
Miata's
Evo's
WRX
RX7
BMW's
300ZX
3rd gen Camaro's
Old School Chevy's
Skyline's
Supra's
I've never understood the point in buying an import and then doing a domestic swap. I mean...buy a domestic and swap it in. Otherwise get original and do a lesser known swap from another import.
there are about 6 LSx swapped s2000's.......two of them here in memphis......along with my Civette and wrx....both one-offs.....dont attempt this swap if you dont know what you are doing.....you will be modifying the subframe, firewall, front frame crossbar, beefier rear end.....
Ethan's s2000 will be the first full wire tucked and shaved 6.0 swapped s2000 on work wheels.....so clean!!!!!
