Window regulator question
My window regulator was off track i messed with it had no luck went to a local window place and they told me the regulator is bent. Ive called 3 different junk yards and have no luck I'm going to go to a junk yard where you pull the parts yourself and i know they have a few hondas I'm curious if and other manual models fit into the crx with no modifications. Trying to find this out asap trying to head to the junk yard before dark. Thanks, Randy.
I went through this a while ago, and one thing I noticed was that the window regulators are different for the CRXs with seatbelts on the doors and the CRXs with seatbelts on the pillars. So make sure you make sure they are off of a CRX with the same type of seatbelt system you have.
I thought that maybe a same year Hatchback window regulator might work, but I looked online and noticed that they are a different part number than the CRX. Maybe what I would do is take your current regulator with you when you go to the junk yard, and then just so a visual comparison with the ones you find in the yard.
pony express
Jan 22, 2003 10:06 AM
