crome basemap
Old Feb 3, 2010 | 11:24 PM
Rease3's Avatar
Default crome basemap
i am having major problems with my tune. looking for new basemap
75mm vitaras
eagle rods
dsm450cc
gm 3bar map
cast manifold
57 trim turbo
zex 59300 cam
skunk 2 intake manifold
b16 tb
255 fuel pump
oem fpr
i opened crome p30 bin, imported p28 maps, removed checksum and added quick datalogger and rtp, added boost tables 3 bar map 6 boost tables, dsm 450cc(90-94 blue tops if correct)(offset 0.00 see 3nd image below)
this is where i left off.
low cam ing
low cam fuel
advanced tab when setting fuel multiplyer
Injector offset
not sure where to go from here. i have hulog and ostrich and chip burner.
hulog - com 8
ostrich - com 9
burner - com 6
do i need to change com ports to match lower numbers
Old Feb 4, 2010 | 07:53 PM
Rease3's Avatar
Default Re: crome basemap
can any one help me get my car to idle. i have played around with the offset when setting the injectors. 47 offset for 450 injectors when tried to start motor i will crank over and wideband will read 14.x but wont run
Old Feb 8, 2010 | 11:20 AM
94civiccupew/b7's Avatar
sorry if it's a dumb question but did u change in your multiplier calculator your injector size? from what i see in crome you have your low cam fuel tables the same as a stock p28 with 240cc injectors, which with 450's would be to much. you could be drowning your cylinders
Old Feb 15, 2010 | 06:08 PM
hoya_10fintec's Avatar
^ try that if you didn't..
Old Feb 16, 2010 | 02:38 AM
GhostAccord's Avatar
Have you checked that you are getting spark to the cylinders along with the fuel?
What DSM injectors do you have? Blue top (90-94) Black top (95-99) that will determine the correct battery offset.
Not a dumb question. If you look at the bottom of the low cam screen shot. You can see that he has a final fuel multiplier of 0.53. If it were a stock P28-P30 map it would show a fuel multiplier of 1.
Old Feb 19, 2010 | 12:35 PM
siregcivic's Avatar
if you send me your .bin i can modify it to get your car to run.
dj211855
Engine Management and Tuning
13
Dec 27, 2011 06:48 PM
likwidchz
Sep 12, 2011 06:57 PM
Golden Eagle
Sep 13, 2010 07:19 AM
tekturbo
Jun 6, 2008 03:06 AM
