lower control arm replacement
Old Sep 5, 2002 | 05:29 PM
illusion's Avatar
Default lower control arm replacement
my helms manual doesnt really give any description of how to remove/replace the front lower control arm. just a diagram of how everything fits in. im wondering, is it that difficult of a job that i should have a place (dealer?) do it? are there any special tools that i would need? can it be done on jackstands?
also, should i play it safe and buy a new control arm from honda or will a junkyard piece suffice?
Old Sep 5, 2002 | 09:39 PM
Flamenco-T's Avatar
Default Re: lower control arm replacement (illusion)
it can be done, you need to remove the lower ball joint and 3 bolts...
Old Sep 5, 2002 | 11:34 PM
ndogg's Avatar
Default Re: lower control arm replacement (Flamenco-NA)
the lower ball joint is a BITCH to get out. you will need a puller to get it off, banging on the controll arm WILL NOT WORK. if you get it by banging on the arm, then you are a lucky bastard. or you really fucked up your control arm.
Old Sep 6, 2002 | 10:52 AM
wakaru's Avatar
Default Re: lower control arm replacement (ndogg)
the lower ball joint is a BITCH to get out....
If your speaking of just separating the ball joint from the lca, not so...
Jack up the suspension just enough to put the end of rachet between the ball joint and lca. Go ahead and thread the nut down to where the nut is flush with the end of the ball joint stud. Slowly lower the suspension and it will pop loose. Then thread the nut the rest of the way off.
Also, do a search here using "ball joint", lots anecdotal advice.
Old Sep 6, 2002 | 12:24 PM
illusion's Avatar
Default Re: lower control arm replacement (wakaru)
yeah doh! forgot about the search function here because usually it never works. this time it did! great info to be found.. this thread looks especially helpful
https://honda-tech.com/zerothread?id=211147
and i was gonna post the question to the competition forum but i figured here would be more appropriate. thanks guys ill do some reading before jumping into it.
Old Sep 6, 2002 | 05:14 PM
Jared's Avatar
I always hit the lca with a large hammer to loosen the ball joint. I dont use pickle forks at all because they are prone to bust the boot, and in my profession, that isnt acceptable because it has to go back together and look like it has never been apart and i'm not into buying ball joints for other ppl.
Old Sep 7, 2002 | 04:28 AM
illusion's Avatar
Default Re: lower control arm replacement (Jared)
i always get scared using the BFH method. =\
Old Sep 10, 2002 | 02:45 AM
illusion's Avatar
does the spring/shock assembly need to be removed when replacing the lower control arm?
Old Sep 10, 2002 | 05:13 PM
illusion's Avatar
unclematt
12
Jun 2, 2016 04:31 AM
butter99
27
Nov 28, 2008 04:53 PM
androide016
Jan 8, 2008 11:10 AM
94vtirozguy
Apr 14, 2006 11:37 PM
94vtirozguy
Suspension & Brakes
Apr 3, 2006 08:32 PM
