can any one me wit this set up?......
Old Feb 3, 2010 | 07:07 PM
sport injector's Avatar
Default can any one me wit this set up?......
.... whats up guys im trying build my gsr for an all motor and was curious if my approach is good and how many hp i would probly be pushing
gsr with
4-1 header
ls rods
ls crank
p30 pistons
type-r camshafts
type-r springs n retainers
aem cam gears
if anyone has advice on it or suggestions please lemme noe ... thanks
Old Feb 3, 2010 | 07:12 PM
Default Re: can any one me wit this set up?......
anyone?....
Old Feb 3, 2010 | 07:28 PM
Shimakid12's Avatar
sounds to me like similar to an ls-v setup, but with a gsr block. What kind of 4-1 header are you going to use? This will be a pretty big determining factor in the final power output, as well as the final exhaust choice (a 2.5ish to make the most power I'd say). I think the power output would be close to that of the type R range, because you're using R cams and the specs are similar. It will probably make a bit more hp and torque because of the stroke difference from the ls crank, depending on the tune.
Old Feb 3, 2010 | 07:50 PM
thanks.... i have evo2 greddy 2.25 exhaust... ima get probly hytech replicas... and a dyno tune.... what do you think?
Old Feb 3, 2010 | 08:01 PM
Shimakid12's Avatar
Hytech replicas, from what I've read, are alright at best. They are priced right, but they don't make comparable power to that of a real hytech header. I've read fitment can be a pain in the *** with the replica headers, but if the nice price out weighs those issues then I say go for it. I've read quite a few good things about the rmf narrow style headers Kiddracing is selling on here, and they're priced pretty good. I would almost rather use an oem jdm 4-1 header because they have proven bang for the buck performance compared to knock off headers.
As far as the exhaust goes, I think you would benefit quite a bit from a 2.5 exhaust. 2 and a quarter is usually thought to be more appropriate for a d series build. Also, going with a thinner head gasket is something you could consider, to raise the comp a bit for a boost in power. Something to think about. Other then that though sounds good to me, I hope it all works out for you.
Old Feb 4, 2010 | 04:21 PM
wow.. sounds great thanx... yeh i was thinking about buying the oem header as well but people tell me go aftermarket.. eh.. guess they dont know as much... and 2.5 sounds good as well... and with the headgasket, what brand is reliable?...i know eagle is good but any thing else ud recommend?
Old Feb 5, 2010 | 09:34 AM
MR.johnson's Avatar
i had about the same setup in my teg. with bloxB's made 192...
Old Feb 5, 2010 | 02:34 PM
TheCrimsonGhost666's Avatar
Im trying to go with the exact same setup, but im still deciding between p30 pistons or RS machine pr3 pistons that are half the price with rings, but anyway good luck and let me know how it goes.
Old Feb 5, 2010 | 03:40 PM
Natural Aspirations's Avatar
I believe that unless you need to use a LS crank and rods its not worth loosing the better and stronger GSR rods, unless of course you run an aftermarket rods.
Aftermarket rods are not absolutely necessary but I feel that while OEM rods have been used with success I feel that they are a weak link.
Old Feb 5, 2010 | 08:25 PM
wait... how much do the rs machine pr3 cost?.. and where
Old Feb 5, 2010 | 08:33 PM
http://cgi.ebay.com/ebaymotors/RS-MA...Q5fAccessories
Their $160 with rings, and there great quality. Also they have CTR and ITR replica pistons in stock bore up to 85mm I think.
Old Feb 6, 2010 | 01:27 PM
would the 85mm fit a gsr?
Old Feb 6, 2010 | 04:10 PM
Is your gsr bored to an 85mm? Stock bore is 81mm, I was just saying they have pistons ranging in size from stock bore which is 81mm up to 85mm.
Old Feb 6, 2010 | 04:32 PM
SergEK's Avatar
gsr with
4-1 header
ls rods
ls crank
p30 pistons
type-r camshafts
aem cam gears
Waste of time
H22a...more power and more potential later on and OEM build out of the box...heres a simple bolt-on mild cam dyno...Pro 2's would be better but you get the idea
http://forums.evans-tuning.com/viewt...hp?f=31&t=5097
GSR615
16
Jun 16, 2010 09:16 AM
acuracer5
10
Jan 22, 2010 01:35 PM
killerpenguin21
36
Aug 2, 2009 09:55 PM
hondachris1994
Aug 31, 2007 09:28 PM
eddiecut
Jun 21, 2003 03:47 PM
