99 crv door lock actuator
why is it that, when it gets cold, my lock doesnt work? (central lock)
but when you press the lock and unlock thingy inside....it works...
can someone tell me whats up, or how to fix it...
i mean, if the actuator is the problem, then it should lock/unlock at all
when i lock/unlock it inside right?
that happens a lot of times to me.....
ive read somewhere that id dis alligns or freezes,
try spraying wd40 or liquid wrench, it did worked
for me.... all around the actuator!
hth...
hth...
i mean, if the door lock actuator is the problem, then it should lock/unlock at all
If its during the cold months its obvious when you get in your car and turn on the heat it creates moisture and condensation inside the door and covers the lock mechanism. When you get out of the car the moisuture freezes and thus freezes the mechanism. I have the same problem on my CRV.
Unlocking from the inside, outside or electronically with a remote, there are different linkages involved so one portion will work but not the other mostly due to adjustment misalignments due to normal wear and tear and plastic parts wearing out, some due to dirt and dust preventing full travel and yes, lack of lube or old grease type lube getting too hard and blocking good movement.
nestor
23
Oct 30, 2014 04:25 PM
Heat
Jul 4, 2003 07:26 AM
