What are the torque specs for GSR spark plugs?
Old Sep 5, 2002 | 05:04 PM
ebelp's Avatar
Default What are the torque specs for GSR spark plugs?
I just bought my plugs (NGK BKR6ES-11). How important is it to have them torqued to specs? On the box it says to hand tighten, then 1/2 to 2/3 turn.
Old Sep 5, 2002 | 05:10 PM
vteg's Avatar
New User
Default Re: What are the torque specs for GSR spark plugs? (ebelp)
18-21 ft-lb. I normally use 20.
Old Sep 5, 2002 | 05:24 PM
ingrate's Avatar
25 Year Member
Default Re: What are the torque specs for GSR spark plugs? (vteg)
From my 1997 integra owner's manual:
6. Torque the spark plug. (If you do not have a torque wrench, tighten the spark plug two-thirds of a turn after it contacts the cylinder head.)
Tightening torque:
13 lb-ft (1.8 kgf*m, 18 Nm)
Tighten the spark plugs carefully. A spark plug that is too loose can overheat and damage the engine. Overtightening can cause damage to the threads in the cylinder head.
Old Sep 5, 2002 | 05:33 PM
Trigun's Avatar
Default Re: What are the torque specs for GSR spark plugs? (In7egrity)
13lb-ft is correct
Old Sep 5, 2002 | 05:38 PM
Area57's Avatar
13 lbf-ft according to Helms manual(96 integra).
I had one shoot out of my 86 prelude si(R.I.P.) when I tried to start it. It stripped the threads out of the head. I had to use a heli coil kit to reinstall it. Needless to say the motor never ran right again. Then it wouldn't pass emissions
What a shame, I had to get rid of her and get a GSR
Old Sep 5, 2002 | 06:01 PM
Ricky Rojales's Avatar
No! 13 ft lbs.
Old Sep 5, 2002 | 06:21 PM
vteg's Avatar
New User
My 18-21 is from NGK's website. It is listed as the spec for aluminum heads. I guess I will use the helms spec next time. I have never had a problem with NGK's spec though. I would give you the web page, but it is in my palm and I used plucker. I have to figure it out.
Old Sep 6, 2002 | 01:28 PM
ebelp's Avatar
While I'm cleaning the threads on the head....should I be worried about pieces of debris that may fall down in there?
Old Sep 29, 2002 | 07:15 AM
ragejed's Avatar
Would like to know this too
Old Sep 29, 2002 | 10:15 AM
ingrate's Avatar
25 Year Member
Default Re: What are the torque specs for GSR spark plugs? (ragejed)
before you remove the spark plugs from the kind of heads that have that chamber where the spark plug goes into (like most hondas), you're supposed to use a pressure blower or vacuum or whatever and get all the crap out of that chamber so nothing falls into the spark plug hole.
Old Sep 29, 2002 | 01:29 PM
ILOVEGIRLS's Avatar
are the torque specs the same for the ls , gsr, typer..lsvtec?
Old Sep 29, 2002 | 01:37 PM
maxxdout's Avatar
Default Re: What are the torque specs for GSR spark plugs? (ILOVEGIRLS)
something to keep in mind.
All torque wrenches reguardless of type are most accurate in the middle 2 quarters. What that means is the top and bottom 25% are not as accurate as the middle 50%. meaning. out of a 100ft lb wrench the first 0-25 lbs and the 75-100lbs are less accurate of readings as the range of 26-74ft lbs.
basically use the correct wrench for the job. for small jobs a good 1/4" drive torque wrench set in "inch" pounds is probably more accurate.
but again, this is probably getting too critical, but for those that care, this would be the proper procedure.
Old Sep 29, 2002 | 01:44 PM
AzG35's Avatar
I believe all 4 cylinder honda motors are 13 ft-lbs. If I remember correctly, v-6's are 16 ft-lbs.
Old Sep 29, 2002 | 02:29 PM
AcuraRacer112's Avatar
Default Re: What are the torque specs for GSR spark plugs? (AzSi22)
a lil OT.. I forgot where i was reading this but the factory OEM spark plugs in a comparative test acutally did better than any aftermarket plug...just a lil FYI
That is for a GSR
Old Sep 29, 2002 | 07:51 PM
Mns's Avatar
Mns
Default Re: What are the torque specs for GSR spark plugs? (AcuraRacer112)
http://plugs.janmax.com/comparison.aspx
Old Sep 30, 2002 | 12:53 PM
maxxdout's Avatar
i think you are correct. Most all aftermarket plugs are hype. just replace with OE plugs, even from honda is pretty cheap. try ahmotor.com
zach1288
Aug 5, 2019 05:10 AM
kornerk12
10
Apr 2, 2011 06:03 PM
TimsTeg
Apr 20, 2003 08:55 PM
wessieball
Aug 9, 2002 10:16 AM
paulyman
May 20, 2002 07:11 PM
