900hp goal! help me reach it! what turbo??
Hello im wunfstgsr i have searched a good amount and now want to start my thread im building a daily driven 98'' gsr sleeper and having JG build me a longblock they say is good easily to 800hp and want to reach 900hp or as close as i can, right now a supper charger setup good for 290hp is being put on the motor but will soon be removed for the final hp goal desired by me when i find out what and where to get my turbo setup, for i have no clue where to get it but i do know i want a new not used! top of the line turbo/products. my goal is big hp! at least 900hp,a fast spooling turbo, a linear tq band much like my supper charger tq curve, must be reliable this will be a daily driven car and wont be raced mostly for show and personal acheivment. but i dont want a turbo that lags! this is where im suck! also i would like a complete kit to make my life easier! so heres a breakdown of the motor its almost a copy of tony palos t1 gsr, so far what i know im going with is any input is appreciated,
b18c-1 JG stg 3 turbo block (9:5 comp. 81mm-82mm iron sleeves ect.
JG redline series head (full port)
ITR ex cam GSR intake cam (pending on getting turbo cams but dont know which ones)
74mm tb
JG elderbrock i.m
1700cc injectors
hondata s300
Garrett gt4294r turbo (is this a good choice for my turbo/goal?)
full race top mount divided collector
tial sport 44mmx2 wastgate
t1 race development intercooler
garrett 24x12x3.5 core
4'' catback-4'' magna flow muffler
walbro fuel pump
usdm itr trans.
74mm tb
JG elderbrock i.m
1700cc injectors
hondata s300
walbro fuel pump
usdm itr trans.
your gong to have a few problems
-anything more than 450-500 is very hard to keep traction on the streets
-on a small displacement engine you cant have 900hp and quick spool
-you will HAVE to run race gas in which your dd is out the window
-900 hp is going to be a very very large challange on itself.
- your single walbro most likely wont supply enough fuel
- reliable and 900 hp dont belong in the same sentence really.
on top of that good luck im sure you will have alot more harsh people than me.
also i dont think 900 hp is even possible on 1.8l.
the biggest problem your going to have with this build is the company your having build your motor and the company you giving your money to... I would deff go another route... They are not good to there customers, have done us wrong number and number of times. Do a search on them and you will see..... get your stuff back asap.
just for piece of mind!, why is JG not repudable? iv built many motors but i got a good deal on a b16 jg ported head so i went ahead and wanted jg to assemble everything since the heads already ported by them and $300 is a decent price for labor to assemble everything imo and i got the stg 3 block with $500 off, but i think i can break 800hp on a 1.8l and i might run race fuel but would want to ovoid it and i will have upgraded axles to support the hp as well as better tires but not slicks, its possible i know it is someone help me out, also i will talk to my tunner more
your neve rever going to run 900hp in a dd unless you want to throw 1000 dollars a day just to maintain the car
if so then it could be possible
I've had nothing but bad luck from JG. DO NOT GO THERE. I had to have my motor rebuilt because of them and I never got to start it. I had to call them numerous times to figure out what was going on with my motor. It literally took them 11 months to send my motor back and it was a mess. Oh and they promised me it wouldnt take no more than 3 months. The reason why I decided to rebuild it was because of the following: One of the nuts on the pick up tube was laying in the oil pan, they never fully cleaned my block. I had metal shavings everywhere from god knows what. They painted over my old water pump and oil pump gaskets and assembled it that way. I had two pistons/rods that were put together too tight resulting in me buy new arp hardware for it. The arp bolts showed signs of stretching. And my bearings had a cleance of something like .0001 (Something really small, I cant think of the exact specs on it at this moment) Go with someone else. You will regret it going with JG. They are more than happy to take your money but are VERY SHITTY with their customers. I really wish I would of done some more research on them before I decided to send them my motor. Please dont do the mistake I had to do. Their **** ups have cost me over $1500 in repairs. And like I said before the motor hasnt even ran yet, and its been over 2 years and my motor sits in my garage slowly getting put back together because of the extra money I had to put into it to fix it right.
DO NOT GET WORK DONE BY JG ENGINE DYNAMICS. I've had it in my sig since the first day I joined HT
so if jg is no good who in c.a should i send my motor to be built? or at least the block? i want a built sleeved block and thought jg was a good deal.. my local shop wants $700 just for labor of assembling the block and that's with me supplying all the parts, sounds to much.
Find ppl that have cars making 900hp and have them build your engine or whoever builds their engine build your engine. Besides that your goals are unrealistic. In a fwd car having big hp numbers mean nothing. Work your way up. Just to put down 750hp+ you might need a $4000 plus transmission.
This car/setup is a good example to follow. The owner never had a car over 300whp. The setup is a very big set up but the parts/setup you listed is pretty close to this car. What makes the most sense on the car is the boost by gear (traction) and 235 MT drag radials.
http://www.youtube.com/watch?v=GvW0apRvcDI
http://www.stewartengines.com/
Ive heard good things about these guys also I have heard good things about Benson
if ur building a engine thats is going to be built for over 5k then dont skimp out on assembling it with a reputable shop. Obviously it sounds like you dont have much experience with building motors so doing it urself is not an option. But giving ur engine away and throwing some cash to a shop is not going to cut it.
i help you out to get 900hp,throw away your b series,grap you a h22 fully built that **** to handle alot of boost 30+psi for maybe 4 to 6 run down a track,then check your bank account make sure you got enough $$$$$$$$$$$$$$$$$$ to help you out,we cant help you friend,but money can,sent you from cali there alot of place there,taht can help you out(that if you got money)
You ever see those car accidents when the car is just rolling over again and again sideways with no end in sight?
Yeah that's kinda what I feel like reading this thread.
i dont know if ur half retarded or what
