obd0 to obd1
Old Feb 3, 2010 | 02:22 PM
4g4dcruisin's Avatar
Default obd0 to obd1
Im looking around for a diagram or a detailed how-to for wiring obd0 to obd1 vtec/dizzy/and o2 sensor.
i plan on going from an obd0, CONVERTED to mpfi, non vtec to a z6.
Old Feb 3, 2010 | 02:24 PM
8dxhatchy8's Avatar
Default Re: obd0 to obd1
look at the FAQ's
Old Feb 3, 2010 | 02:32 PM
4drEF's Avatar
Keyboard Humorist
Are you planning to purchase an OBD0 to OBD1 conversion harness?
http://rywire.com/store/-c-27.html?o...e6678e7ea23f1e
Looks like it's $300 and you would have customer service and support from them.
You could also convert to MPFI yourself and then just get the OBD0 to OBD1 jumper for $190.
Or you could do the whole thing yourself.
Just convert to MPFI and then have fun making your own OBD0 to OBD1jumper
OR
cut your plugs, trace all wires, and solder on OBD1 plugs.
http://www.phearable.net/tech/wiring/pinouts2.htm
Old Feb 3, 2010 | 02:58 PM
OR
im already mpfi, i just need the to wire an obd1 dizzy, ecu, vtec and 4-wire o2.
Old Feb 3, 2010 | 03:02 PM
4drEF's Avatar
Keyboard Humorist
Personally I would cut ECu plugs and make it perma-OBD1.
I'm like that though. Electrical doesn't intimidate me.
Old Feb 3, 2010 | 03:06 PM
I did something similar to that! i turned my obd0 plugs into obd1 plugs. My obd0 plugs were being a bitch one day so i hooked up some nice new obd1 plugs that worked like a dream.
If i get ahold of an obd1 wireharness ecu side i could probably just start hackin and color matching most of them, then see what i'de be missing.
How did Sh!ft get that under his name?
dr_latino999
236
Mar 28, 2020 12:34 AM
projsectEF
Jul 25, 2006 12:32 AM
skud_dusty
13
Apr 25, 2003 11:51 PM
