Suspension & Brakes Theory, alignment, spring rates....
11" rear rotor?
Old Feb 3, 2010 | 10:29 AM
sohcrx91331's Avatar
Default 11" rear rotor?
anyone know of a car with a 4x100 bolt pattern that runs 11" diameter rear rotor stock?
Old Feb 3, 2010 | 11:57 AM
phunhaus's Avatar
Default Re: 11" rear rotor?
No, but you can order redrilled 10.9" rear rotors from Fastbrakes.
Old Feb 8, 2010 | 02:45 PM
that funny cuz im going to order their 11" kit for my crx but i want to run solid rotors instead of the drilled and slotted.the reason for this that i hear that heat cracks form where the rotors are drilled
Old Feb 8, 2010 | 04:32 PM
phunhaus's Avatar
They offer solid rotors. I have some from them on my EK.
Old Feb 10, 2010 | 06:50 AM
dr_latino999's Avatar
Redrilled S2000 rotors + ITR Calipers + Custom Bracket. Without redrilling and using OEM parts, I don't know of other many other options.
Old Feb 11, 2010 | 05:37 AM
unusual71's Avatar
This is what i've been doing with good results
this year i will be going RSX calipers though.
S2K rotors are 11.2 inches and the business area is about .350" thick
stock, base model integra calipers are designed for .250-.275" thick rotors
so this is a bit of a problem. pretty sure GSR calipers are the same.
no idea what ITR calipers are. S2K and RSX rear calipers are the same.
maybe some sort of newer civic has these calipers also, not sure
hope this helps
Old Feb 11, 2010 | 07:19 AM
GRANT!'s Avatar
AEM 2-piece rears are 11" (4 x 100)
Old Feb 13, 2010 | 07:20 PM
thanks for the help guys much appreciated! (:
Mrob91GS
Feb 17, 2005 08:31 PM
Solscud007
Dec 8, 2004 10:00 PM
fastbrakes
Oct 24, 2001 01:35 PM
