Need your advice
Here's the situation, I have a 1990 Honda Accord EX and recently started getting the check engine light...a friend told me its probably the O2 sensor..so i take it to the dealer and they tell me i have other problems besides the O2 sensor..
The List:
1)O2 Sensor $340.00
2)EGR ports clogged $270.00
3)Front engine seals leaking $565.00 w/ timing belt,water pump,drive belts
4)Oil Pan and gasket $360.00
5)Power steering rack leaking $795.00
Are those prices about right? eventually i want to get all this stuff done but what should i start with..what takes priority..
Im thinking of maybe taking it somewhere else to see if i can get a better price...but i do want to fix what ever is wrong with it...i just cant afford all that money right now, so i want to do this in segments..once aguain where should i start?
your suggestions will be greatly appreciated..Thanks
The List:
1)O2 Sensor $340.00
3 look sabout right, I can't speak for the other ones. You may want to have the dealer do that one and try to take the rest to an independent Honda specialist.
HondaAccordSE1997
Jul 10, 2007 05:38 AM
Jason kiDD
Oct 29, 2003 06:33 AM
