Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
not sure what to do
Old Feb 2, 2010 | 05:26 PM
bishop1080's Avatar
Default not sure what to do
So I have a 2001 Honda Civic Ex, for about 6 months now, my heat only blows when I am accelerating, when I slow or come to a stop it blows straight cold air. Now I have been told that it's probably my thermostat that is sticking, and to get it replaced which I am going to do. Just recently my car has started overheating. Once I get to about 40mph, when my heat is kicking, my temp goes back down. Just today my temp gauge started going all the way up to hot, and does not go down. I've had to keep stopping and letting it cool down before I can drive it again. I don't know much about cars, but I;m hoping someone has some insight on what my problem could be. As far as I know both my fans are running well, but other than that, I am totally clueless!! Can anyone help???
Old Feb 2, 2010 | 07:13 PM
Rob.C's Avatar
Default Re: not sure what to do
Same thing happened to me, turned out my main fan wasn't working.
Old Feb 2, 2010 | 07:18 PM
bishop1080's Avatar
Which one is the main fan?? Excuse me for being pretty dumb when it comes to cars...lol!! I know I have 2 but don't know which one is which. I tested them too, i turned my ac on with my heat and both would come on then click off, on then off. I'm just trying to avoid taking it in to the dealership, if it is an easily fixed problem, thank you for responding too Rob
Old Feb 2, 2010 | 07:25 PM
Rob.C's Avatar
The fan on the right, not too sure if its suppose to turn off and on tho.
Old Feb 2, 2010 | 07:46 PM
bishop1080's Avatar
hmmm, ok, thanks, i will check it out
Old Feb 2, 2010 | 08:38 PM
warthog1984's Avatar
Sounds like a probable low and/or plugged/clogged/blocked radiator or condensor. Try opening the radiator cap when COLD and see where the fluid level is (should be full).
If your radiator is full, a simple test for a stuck T-stat is to turn the A/C and heat on when it starts overheating- both fans should kick on and the temp should level off.
If the T-stat seems fine, pop the black plastic buttons holding the upper trim piece and remove it (the plastic with the Honda emblem on the front). Drive around and see what the temp. gauge does. This should greatly increase airflow. If the temp gauge acts normal, this points towards either
1) a clogged radiator needing flushed and/or replaced
2) a radiator/condensor full of bugs and in need of vacuuming.
Hope that helps.
Old Feb 2, 2010 | 08:47 PM
bishop1080's Avatar
Thank you , I will give it a shot!! Thanks for all the info!! I'm desperate to get my car fixed! I will try it though.
Old Feb 3, 2010 | 02:22 PM
bishop1080's Avatar
so, i had my thermostat replaced and the switch on my fan replaced, and so far so good.
Old Feb 3, 2010 | 08:00 PM
Spoon ES2's Avatar
nice sounds like u got it fixed
Old Feb 5, 2010 | 06:25 PM
bishop1080's Avatar
yep, soooo very happy my car has been doing great. thank you guys for all the advice i appreciate it!!!!!!!!!!!!!!
tundra2000
Dec 18, 2010 07:00 AM
Scotland:EF3
Feb 28, 2007 07:18 PM
DrewDown
Aug 23, 2005 12:56 PM
SloCrxDx91
Jun 20, 2005 03:09 PM
alfee
Oct 13, 2004 06:07 PM
