Opinions on my dd suspension setup
Alright well I thought I was done with the car but decided I wanted to do more with the suspension instead of just stock sway bars and h&r springs on stock shocks. So over the past week I picked up a few things. Just trying to get some input on how it should handle or if i picked the wrong parts ect ect. The car is basically daily driven except in the winter months but I do like to push it. Thanks in advance H-T
boosted 1994 integra ls
stock 22mm front sway bar
usdm itr 22mm rear sway bar mounted using the beaks reinforcement kit and stock lca's
progress cs2 coilovers 350/350 spring rates
stealthmode ps delete kit
16x7 +45 wheels 215/45/16
You probably already know but that's (almost) exactly what I plan on doing. One suggestion: You might want to check the condition of your suspension bushings. If they're shot, the chassis won't feel completely tight until they are replaced.
kaiba
Nov 24, 2005 09:50 AM
ill phil
19
Sep 23, 2003 01:35 PM
