b20vtec fuel pump and fuel injectors
Old Feb 2, 2010 | 06:51 AM
negusjuda's Avatar
Default b20vtec fuel pump and fuel injectors
ok ladies and gents lol here is my question. my build is as such:
srp 10.5:1 piston which wit my gsr head milled .010 will net me 11.0:1
stock rods
skunk2 tuner stage 1 cams
mild ported gsr head
skunk 2 intake mani
edlebrock 65mm tb
cheap 4-2-1 header for now
stock cat
tanabe exhaust for a da integra hence why i have a cheap header anything better and i have to get a traction bar
now my question is. do i need to upgrade my injectors and fuel pump for this setup? or just maybe some 310 injectors? or will stock fuel pump and injectors with a fpr be ok
Old Feb 2, 2010 | 02:11 PM
b20VGSR's Avatar
Default Re: b20vtec fuel pump and fuel injectors
i would upgrade jus to be safe so u dont kik lean for any reason but if u r on a tite budget like me stock injectors and fuel pump with a modified fpr will work but then again i have a gsr fuel pump cuz my car is a gsr but u will still be fine but then again u have higher compression so it has a higher chance of kikin lean i say upgrade 310cc will be fine
Old Feb 2, 2010 | 05:34 PM
00Red_SiR's Avatar
All Motor Mentor
^^^was that English?
Stock should be fine and your tuning system will tell you if you're running out of injector or fuel while tuning on the dyno.
Old Feb 3, 2010 | 08:40 AM
negusjuda's Avatar
i rather not find out when its on the dyno because then i will have to get the injectors and pay another 400 bucks to get tuned again
Old Feb 3, 2010 | 01:56 PM
pradaman's Avatar
i have less then u in terms of a b20vtec stock block with a biult head but my tuner completley maxed out the stock injector im now running a h22 310cc and walbro fuel pump
Old Feb 3, 2010 | 02:18 PM
negusjuda's Avatar
im also running obd0 injectors so i have to figure out what injectors i can run i know the rc peak and hold injectors are for obd0 motors if im not mistaken
Old Feb 6, 2010 | 01:23 PM
negusjuda's Avatar
bump
Old Feb 6, 2010 | 01:42 PM
negusjuda's Avatar
i also wanna know if since i have a 91 integra can i use h22 injectors in my setup and also if i do use them do i need to cut the clips off the h22 and wire them to my harness or does my integra harness work on the h22 injectors
2-logicl
Aug 1, 2006 04:15 AM
hybridEj6
Jan 31, 2005 01:42 PM
jeremy.
Sep 29, 2003 05:35 PM
PTL
Jun 7, 2003 12:53 PM
