Timing belt noises
Old Feb 2, 2010 | 04:40 AM
ezza's Avatar
Default Timing belt noises
I just got my engine back together and running yesterday, i have driven it a little to get a few miles on it to let it settle in a little.
I noticed a noise coming from the engine bay that sounds a little like the buzzing noise of a bee but louder, upon closer inspection it looks like the timing belt, from the intake cam pulley to the water pump it is a blur like its resonating somewhat, but if anything when me and a friend set the tensioner we set it too tight, could this be because its too tight?
Also i dropped my exhaust cam (with gear still attatched) while the engine was stripped and now the exhaust cam gear has a bit of a wobble but i dont think its this.
any help much appreciated
thanks
Old Feb 2, 2010 | 02:27 PM
ezza's Avatar
Default Re: Timing belt noises
anyone?
Old Feb 3, 2010 | 12:32 AM
ezza's Avatar
b
Old Feb 3, 2010 | 02:05 PM
BrownDx's Avatar
A buddy of mine had a similar issue and I tracked it back to the inner timing cover. When re-assembling the inside cover he didn't secure it properly and it was hitting the cam gear creating what I could call a 'buzzing' noise.
Old Feb 3, 2010 | 04:36 PM
fcm's Avatar
fcm
Old Fart
An overly tight belt will cause problems, a "wobble" of a cam gear is not a good thing.
Either of the above can cause "noise" and noise may be the least of your worries. 94
Old Feb 4, 2010 | 05:11 AM
ezza's Avatar
Well it cant be the wobbling cam gear causing the noise as the belt passes over the intake cam gear which is running true and then starts vibrating.
Old Feb 4, 2010 | 05:17 AM
kyden's Avatar
hes just saying the wobbling gear is a bigger issue than the noise (which it is)
Old Feb 4, 2010 | 11:07 AM
ezza's Avatar
Oh,
i was reading about wobbling cam gears and apparently back in the 90's some of the cheap'ish decent cam gears used to wobble, causing nothing other than premature wearing of the timing belt (not that i want that to happen).
but this will be sorted out, i just wanted to know what the noise could be
Old Feb 4, 2010 | 04:43 PM
PyroProblem's Avatar
The wobbly gear is probably throwing the belt out of whack causing it to hit the timing belt cover...
The loud Bee buzz is the probably timing belt hitting the cover. Id pull the timing belt covers to inspect.Youll probably see where theyve been touching...
Good luck!
Old Feb 4, 2010 | 10:29 PM
ezza's Avatar
I have the timing belt covers off atm so it cant be that...I thought it was cathing the valve cover but it doesnt look like it, il take it off though anf have a look for marks
Old Feb 5, 2010 | 09:50 AM
boostedteg1203's Avatar
When you tensioned the belt at tdc did you then rotate the engine three cam gear teeth and then tighten the tension again?
Old Feb 5, 2010 | 10:40 AM
ezza's Avatar
no, i havnt done it the propper way, i havne since found this method out,
Il re tension it and see how it is
Old Feb 5, 2010 | 09:02 PM
j-dmek9's Avatar
also what could cause that is the cam gear cover behing the cam gear, that plastic piece.... when i switched mine cam gears i went with edelbrock ones and got a new timing belt, so i put everything back together and noticed that piece was making that buzz sound.. so i removed it and it was fine afterwards... check that too!!
Old Feb 6, 2010 | 08:52 AM
ezza's Avatar
Il have a check, thanks^
Old Feb 6, 2010 | 02:02 PM
philafelman's Avatar
yeah, make sure the belt is tensioned good and also, while the belt is off check your water pump and tensioner bearings to make sure they are good.
Old Feb 6, 2010 | 02:37 PM
ezza's Avatar
how do i check these? just spin them and see if they go smoothly?
Old Feb 7, 2010 | 11:58 AM
yeah, and when its back together and running, you can check them by using a stethiscope on the water pump body and the tensioner bolt.
b16-ef-si
May 16, 2009 03:23 PM
1_fst_lude
Sep 26, 2006 11:36 PM
acatak
Apr 29, 2003 10:41 AM
Big Teggie
Jan 2, 2003 04:47 AM
