b series stroker guys come in
Old Feb 1, 2010 | 08:34 AM
stl eh2's Avatar
Default b series stroker guys come in
what length rods are you guys using? i see kits come with 137mm length rods and use a short piston. why not use a shorter rod and a normal height piston to get a better rod stroke ratio? Im new to the whole stroker idea so if some of you guys that have done it can just clear some things up thatd be awesome
Old Feb 1, 2010 | 08:40 AM
4piston's Avatar
Default Re: b series stroker guys come in
You are thinking backwards. You want the longer rod.
Old Feb 1, 2010 | 08:50 AM
stl eh2's Avatar
really? i thought it was better to have shorter rods
could you explain this?
Old Feb 1, 2010 | 12:23 PM
all-mtr-teg's Avatar
Shorter pistons are used to prevent the piston dome from smacking the head and valves.
If you used shorter rods and normal pistons, you defeat the purpose of using a crank with a taller stroke.
Old Feb 1, 2010 | 01:26 PM
stl eh2's Avatar
How? The stroke is still the same the rod stroke ratio would just be different
Old Feb 1, 2010 | 01:32 PM
TunerN00b's Avatar
http://www.stahlheaders.com/Lit_Rod%20Length.htm
delsol vti
Jun 15, 2008 01:19 PM
jetlude
Jan 18, 2008 04:43 AM
boosted93vtecprelude
Oct 22, 2005 05:38 PM
