Car stutters in Gear
Old Feb 1, 2010 | 05:58 AM
djkurious's Avatar
Default Car stutters in Gear
Accord 95 EX Manual
284,000 miles
Last night I noticed that the car is bogging only when accelerating in gear. It all started yesterday and the acceleration isn't smooth.
-When I am not in gear, it idles perfectly smooth. If I rev it out of gear, its normal, no misses. Seems to only bog at low rpm's in gear.
-If I am driving and I am accelerating and it starts bogging, I can snap it out of gear into nuetral and it stops bogging. Put it back in gear and it starts bogging again.
Here is the list of repairs I have done within the past 9 months I have had the car:
Timing belt 272,000
Rotors 260,000
Changed Front Brake Pads 272,000
Changed CV Axles (Raxle) 255,000
Changed Tie Rods, Upper Control Arm and Ball Joint and Lower Ball Joints: 260,000
Changed Transmission fluid: 277,000
Changed Rear Brake Pads: 277,000
Seafoam: 277,000
Spark Plugs 280,000
Changed PCV valve 280,000
Oil Change 282,000
Any suggestions to fix this prolem?
Old Feb 1, 2010 | 06:26 AM
1grex's Avatar
Default Re: Car stutters in Gear
Misses under load; coil, plug wire
Old Feb 1, 2010 | 07:26 AM
djkurious's Avatar
Would this mean it's the spark plug wires?
Old Feb 1, 2010 | 07:46 AM
DrZFiNeSt's Avatar
Correcto
Old Feb 1, 2010 | 07:51 AM
1grex's Avatar
or the coil
Old Feb 1, 2010 | 08:25 AM
djkurious's Avatar
Is there anyway I can test the wires? or the coil?
Old Feb 1, 2010 | 01:48 PM
djkurious's Avatar
I checked the wires and no corrosion or any rust on the wires. So I guess it's the coil. Is there any tricks to putting a new coil on? It almost looks plug and play to replace.
Old Feb 1, 2010 | 02:19 PM
meandino's Avatar
They are plug and play. If you have a multimeter you can test both. Look in a chilton manual. It tells you how.
Old Feb 1, 2010 | 04:22 PM
CruiserDan's Avatar
check the egr recirculating plate under the fuel rail bolted to the intake manifold. clean it out. probably full of carbon. Use carb cleaner and a small screwdriver.
Old Feb 1, 2010 | 05:06 PM
djkurious's Avatar
So I replace the ignition coil, drove it and its still stuttering. Then I inspected the plugs, which look good and replaced those also. It is still stuttering. Still no engine light on. Any more ideas? I will clean the egr recirculating plate as posted above tomorrow.
Old Feb 1, 2010 | 05:54 PM
Targa250R's Avatar
be professional
Accord 95 EX Manual
284,000 miles
Sounds like clogged EGR ports.
Old Feb 2, 2010 | 03:34 PM
djkurious's Avatar
Default Re: Car stutters in Gear **ISSUE RESOLVED**
Ok so today I cleaned the EGR ports and now it isn't stuttering! Thanks for everyone's help! Problem fixed.
Ali F. Ahmad
Honda Civic (2006 - 2015)
Aug 6, 2017 01:50 AM
rodimus
Honda S2000
12
Jul 20, 2005 03:57 PM
paawk2000
May 23, 2005 11:46 PM
Jaydeep
Sep 3, 2003 12:53 PM
Jaydeep
Sep 3, 2003 12:48 PM
