Crankshaft pulley hitting timing belt
Old Jan 31, 2010 | 10:17 PM
jessemace57's Avatar
Default Crankshaft pulley hitting timing belt
Well I just changed the timing belt in my wifes 94 accord LX and noticed then that the drive belt and crankshaft pully had rubbed into the timing belt cover and now the new belt is loose and I beleive that is the reason. Has anyone ever experienced this before?
Old Feb 1, 2010 | 03:13 AM
hondamark35's Avatar
Default Re: Crankshaft pulley hitting timing belt
pull it appart and double check everything. make sure you put everything back where it's supposed to go and have everything tight. if it's not done right you could end up scrapping the engine.
Old Feb 1, 2010 | 03:19 AM
v8killaz's Avatar
u probaly installed somehting wrong, mine rubs the plastic peices alot, now the plastic is melted off so it doesnt rub
Old Feb 1, 2010 | 05:46 AM
dleccord's Avatar
did you not snap the lower cover all the way into place?
Old Feb 1, 2010 | 08:30 AM
When I first pulled it apart I noticed that it had been ate completely through the plastic. I just didnt think that it would actually rub the belt. timing cover is completely on at the bottom.
Old Feb 1, 2010 | 02:20 PM
triggerman77's Avatar
i have had this happen on my old 98 accord pully bolt just came loose and it messed up inside the pulley where the key goes. Got a new pulley and i had no more problems. Be sure to use locktite thread locker on the bolt or this will happen again. And if it has rubbed the timing belt change it. Rather be safe than sorry!!!
Old Feb 4, 2010 | 07:08 AM
rdskltn76's Avatar
mine on a 91 accord was like that too. come to find out that my culprit was the bottom pulley (harmonic balancer), the key, and the screw that holds it on too so i had to go to the junkyard and got all my parts for less than a 100$!!!
pmgriphone
19
Sep 4, 2015 08:11 PM
jackson35
Jun 5, 2008 04:48 PM
Tippyman
Feb 18, 2006 09:04 AM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
IntegracinGSR
Aug 21, 2004 08:43 PM
