coolant gauge
Old Jan 31, 2010 | 09:40 PM
DOHC_ZC's Avatar
Default coolant gauge
Im in need of some help ok wen i start my car and let it warm up the coolant gauge goes up to normal temp but wen i drive it goes all they way back down to were it sits wen the car is off wat could make it do this it has a thermostat in it and the line hold pressure so let me know wat u guys think
Old Jan 31, 2010 | 10:07 PM
seanbev24's Avatar
Default Re: coolant gauge
The thermostat might be stuck open
Old Jan 31, 2010 | 10:24 PM
DOHC_ZC's Avatar
i thought if the lines had pressure then the thermostat was good
Old Feb 1, 2010 | 06:47 AM
DOHC_ZC's Avatar
would it make my heat not as warm to
Old Feb 1, 2010 | 09:24 AM
seanbev24's Avatar
If your heat is working normal while the gauge reads cold I would suspect there is something wrong with the sending unit or something like that.
Old Feb 1, 2010 | 09:42 AM
DOHC_ZC's Avatar
no im heat doesnt realy work mostly cold air
Old Feb 1, 2010 | 10:37 AM
seanbev24's Avatar
Ok then I still think the thermostat stuck open.
Old Feb 2, 2010 | 08:09 AM
DOHC_ZC's Avatar
ya i got a new one yesterday and it was stuck open and it wasnt a stock one either it was huge
Old Feb 2, 2010 | 10:00 AM
seanbev24's Avatar
So is everything good then?
Old Feb 2, 2010 | 10:07 AM
DOHC_ZC's Avatar
ya but i think i might have a blow head gasket or it had it before idk theres a little bit of milky in the cap but very little and nothin in radtiator though i think it had one but is was changed but not positve
Old Feb 2, 2010 | 10:18 AM
seanbev24's Avatar
Blown HG is possible but you might just have a little random moisture in there.
Pull the valve cover and see if more of that crap is in there. If you're really worried get a leakdown test or pressure test the cooling system. There is also a tool that tests for hydrocarbons at your radiator cap.
Old Feb 2, 2010 | 10:32 AM
DOHC_ZC's Avatar
well i have a hose runnin down behind my head from the valve cover could that do it
Old Feb 2, 2010 | 10:59 AM
seanbev24's Avatar
Is it the hose on the back left of the valve cover that normally connects to the intake tube? Is it just running off the VC and not connected to anything? If so, yeah I guess moisture could get in through there.
Old Feb 2, 2010 | 11:14 AM
DOHC_ZC's Avatar
ya thats it i just hooked it up to my intake and there was a little in the valve cover but it was by were that peice goes in
djfob
Feb 16, 2018 05:27 PM
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
`chrisb
Apr 25, 2008 07:52 PM
bigislandc2
Jan 4, 2008 07:20 PM
No
Mar 7, 2006 12:13 AM
