Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic cracked manifold
Old Jan 31, 2010 | 09:11 PM
jrm's Avatar
jrm
Default Civic cracked manifold
Has anyone else had there manifold crack? both of my civics have a crack above and below the o2 sensor. Should I weld it or use high temp epoxy?
Old Jan 31, 2010 | 09:21 PM
nothing_shocking's Avatar
Default Re: Civic cracked manifold
If you can weld it, then weld it. Assuming it's a stock header, it doesn't seem like a big deal to me. I had my turbo manifold and my o2 housing crack at the internal wastegate hole if that makes you feel any better.
Old Jan 31, 2010 | 10:04 PM
Djratrap's Avatar
Hi temp epoxy willl not hold, trust me i've tried it. This is because this is a high pressure area and most epoxy's are not made to withstand that. Your best bet is to weld it, or look for a used one as i know a new one will run at least 300. Stupid Honda and their design flaws.
Old Feb 1, 2010 | 05:07 AM
Curiouz_G's Avatar
dont buy an OEM then. A megan header will run you 150.
Old Feb 1, 2010 | 08:29 AM
jrm's Avatar
jrm
is the cat and the header all one piece?
Old Feb 1, 2010 | 09:26 AM
theineffable's Avatar
this is on a dx or lx model?
Old Feb 1, 2010 | 04:39 PM
GriFFIthS's Avatar
I dont know about the US, but here in Canada the Manifold is covered under a 8 year or 160,000 km's warrenty, if its cracked they'll replace it free of change as long as your within those guidlines.
And yes the cat and Manifold are all 1 part, not sure the cost in the states but here is close to $800 from honda. around $250 for a decent aftermarket one.
Old Feb 1, 2010 | 04:50 PM
jrm's Avatar
jrm
I have a 01 and a 02 LX, both near 150k miles and the crack just now became noticeable on cold start on both. What a shame to wast a great performing cat- i'll try my welding skills but in the past thats never worked out well
sidewayz2013
Aug 27, 2014 12:27 PM
broncoman74
Feb 18, 2009 10:46 AM
zenon8890
Apr 8, 2008 03:27 AM
schpiel
Dec 18, 2006 01:16 PM
boostedblack99
Feb 17, 2005 10:56 PM
