help, crack in exhaust manifold!
I have a 1996 Lx with a D16y7 and I just removed the heatsheild on the exhaust manifold because I thought that the gasket had gone bad after noticing some smoke coming from around the manifold. After removing it I discovered there was a crack down the manifold that is about 3 inches long! Should I replace the manifold, have the crack welded, J.B. weld it? What's the best fix?
Re: help, crack in exhaust manifold! (schpiel)
R U serious? sure u can half *** it for now and put j.b. on it, but u'll eventually want to replace it, but while u gotta replace it anyway get a header 4 her.
Re: help, crack in exhaust manifold! (o_fatmike_o)
replace it asap cause a crack on the header is gonna affect the drivability. exhaust leak before the o2 will cause it to run rich
Re: help, crack in exhaust manifold! (fmrprojects)
yeah, it has already dicked it up. I bought a new o2 sensor for it already. I wonder if the leak made the other one fail? Is that possible. As far as getting a header, that is a possibility, but money is tight, and keep in mind this is only a D16y7 with an intake and a cat back, SLOW! If I get the header, just wondering, I have heard both good and bad about the megan racing one.
go to your Honda dealer and have them replace it for free if it is causing a CEL.
95-97 civics have 150k mile/ 14 yr. extended emissions parts warranty.
My 96 hx had a crack in the exhaust manifold, and they replaced it along with the o2 sensor for free!
Re: help, crack in exhaust manifold! (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">go to your Honda dealer and have them replace it for free if it is causing a CEL.
Okay, so I just talked to the guy at the Honda dealer. It is under warranty!!!! Thanks sooo much! I have an appt for tomorrow!
put your old O2 back in if you have it and keep the newer one for a spare. No sence in loosing a good O2 sensor at the 120 a pop
Re: help, crack in exhaust manifold! (instructor74)
they all do that, good luck finding one at a junkyard that doesnt have that notorious crack.
You could relocate the cat convertor to underneath and run some other header if you plan on keeping the car
94 IntegraLS
07-21-2011 02:12 AM
