skunk2 pro3 cam Questions!
ok i have some skunk2 pro3's for my ls-vtec.
some of the factors :
type r head,
b18b1 block
oem 3 layer headgasket
question is how high does comp ratio have to be to run these cams,
and
what pistons can i use for the right piston-valve clearance.
any help would greatly be appreciated!
thanks
type r head,
b18b1 block
and
thanks
There is no 'minimum' compression required. You will net better results and part-throttle diveability as compression ratio increases.
There is a point at which you would make more power with a smaller cam.
Depending on a variety of factors (including headwork, supporting bolt-ons, etc), I would run Pro3's on a 1.8L with 12:1-13:1 CR or higher, and as displacement increases, the need for more compression decreases. A 2.0L would do well with 11:1 CR and Pro3's with the right supporitng mods.
You might have to notch the pistons because the valves will come down so low they will tap the tops of the pistons on a high compression piston because they are such a big cam.
Endyn Rollerwave is perfect from that prospective.
Would it be not gaining as much power as it can with a 11:1 CR?
I don't believe there is a more aggressive cam then the Pro3, unless you consider the toda killers, just trying to understand the ideal cam for this type of setup.
With 12.5:1 compression it would make more power than the same setup at 11:1. Most of the time you can recomend what to use based on a guideline but in the end, the engine is going to tell you what it likes through testing and comparing.
