knock sensor! p30 ecu help
ok i got everything i need for my gsr into ls swap. but im reading that i need to wire a knock sensor up for my vtec to work correctly. i picked up a chipped p30 ecu today and plan on using that. my boy hasa b16 delsol with a chipped p28. it pulls vtec hard but when i put my ecu into his car it didnt seem to pull as hard in vtec like it was kinda dragging. so i take it that the ecu is not chipped to bypass a knock sensor. so i heard i can bypass the knock sensor by grounding some type of wire?? anyone heard of this. i will eventually get a chipped p28 from john vega but i need it to run decent for the moment. oh and i cant wire a knock sensor because the one on the motor is broken off.
b16civicrida
Mar 2, 2006 02:36 PM
