rule of thumb for ignition and fuel trim?
Old Jan 31, 2010 | 11:39 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default rule of thumb for ignition and fuel trim?
anyone have suggestions where would be a good place to set my ignition and fuel trim for intake temp and coolant temp?
setup in sig, tuning with neptune.
Old Feb 2, 2010 | 06:38 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: rule of thumb for ignition and fuel trim?
??? no tuners in here?
Old Feb 2, 2010 | 06:55 AM
HRTuning's Avatar
The stock settings are actually pretty good. If your particular setup needs some adjustment, I'd just tweak from that starting point.
Old Feb 2, 2010 | 09:56 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
I had some detonation during this last cold snap (FL) car was tuned at 85deg and and it was pinging like a ***** when it was in the 30's... any suggestions, maybe its not the trim?
Old Feb 2, 2010 | 10:00 AM
HRTuning's Avatar
Hmm... I don't know how you have the IAT trim setup, but it would be adding fuel, not taking away. Perhaps it wasn't adding enough. Do you have a wideband setup? How did that look? Did ECT reach normal temps?
Old Feb 2, 2010 | 10:10 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
trims were stock setting... thats why I was asking, my tuner said that typically you should take away timing at lower iats, but that goes against every bit of the (limited) knowledge on the matter that I have... ect was norm, the one thing i did notice is that the turbo spooled a bit earlier than normal, didnt have a datalog because i didnt want to keep doing it. Not sure on the afr's.
Old Feb 2, 2010 | 10:16 AM
HRTuning's Avatar
You can retard timing for lower IATs. It was probably spooling quicker because it's running richer. You'll honestly have to throw a wideband on there next time and see what it's doing before you'll be able to figure out where it's at and what needs to change. As soon as your setup is flowing more air than stock those correction numbers may need adjustment.
Sher1_ZN
Nov 7, 2011 02:24 PM
4LugR
Nov 15, 2008 02:26 PM
Boosted_B_Series
Nov 10, 2008 03:29 PM
NXAccordTO4B
Nov 19, 2003 12:12 PM
justinCO
Sep 12, 2002 03:20 PM
