Fuel system sketches
Old Aug 26, 2002 | 09:13 PM
justinCO's Avatar
Default Fuel system sketches
I sketched these up a little while back to help determine exactly what pieces I need to get my fuel system setup. For most ppl they are pretty simple but I did it to help me see where each particular piece went. I think they may help others that are in the same situation as me. The sketches probably look pretty familiar since they are based on Arturbo and Dustin's fuel setups respectively Anyways, here they are. Let me know if I have gotten anything wrong, hehe. I included Earls part numbers also where I could.
Fuel setup #1, for low boost, stock engine:
Fuel setup #2, for more boost, built engine:
Enjoy!
Justin
Old Aug 26, 2002 | 09:31 PM
HybridKOOP's Avatar
Default Re: Fuel system sketches (justinCO)
This is hillarious... I had planned to begin the SAME type of drawing (fuel system) tonight for my project car. Haha... Nice work.
EDIT: Is is me or are you missing the fuel pump(s)? Heh
[Modified by HybridKOOP, 6:42 AM 8/27/2002]
Old Aug 26, 2002 | 09:49 PM
justinCO's Avatar
Default Re: Fuel system sketches (HybridKOOP)
Yes the fuel pump is not there. A Walbro GSS-342 would be the fuel pump, atleast that's what I'm going to use. This was mostly done to diagram the SS line and Earls fittings, where they go, and what they connect to
Justin
Old Aug 26, 2002 | 10:21 PM
HybridKOOP's Avatar
Why not the Aeromotive 1000hp inline?
Old Aug 27, 2002 | 01:02 AM
RoaringTurtle's Avatar
New User
hey nice
good job on the drawings
anyway you could scan them as well?
Old Aug 27, 2002 | 07:53 PM
justinCO's Avatar
Default Re: Fuel system sketches (RoaringTurtle)
Whatever fuel would work will work, heh. I am just going with the Walbro personally.
I would have scanned them but the scanner is at my friends. If I ever get them scanned I will repost the pics...
Justin
Old Aug 28, 2002 | 07:36 AM
Jason kiDD's Avatar
Why not get rid of the extra fittings and have the FPR connected right up to the rail.. See I saved you a few dollars already. Can you buy me a pizza with pepperonies?
Old Aug 28, 2002 | 07:48 AM
VaporTrail's Avatar
New User
those things SUCK for a daily driver. Sounds like you have a lawn mower attached to the rear bumper. The Bosch inline is a good choice for a daily driver.
Old Aug 28, 2002 | 10:10 AM
justinCO's Avatar
Default Re: Fuel system sketches (VaporTrail)
Correct me if I'm wrong. If I was to use an inline fuel pump, such as the Bosch you mentioned, would I *not* need the intank Walbro GSS-342? Or, if I use the GSS-342 intank, is there no need for an inline pump? Or do I need to use both?
Justin
Old Sep 12, 2002 | 09:07 AM
Smashback's Avatar
You know guys, I was thinking...why are you all using -6 for your feed AND return on your aftermarket FPR setups? Using a -6 feed, a -4 return is more than adequate for a return.
First, your stock system is setup the same. The return is smaller than the feed. Why? Because you are not going to be returning the same amount of fuel to the tank as you are feeding from the tank. Hence the -4 is more than adequate for the return line.
Just an observation. I set mine up this way ... and as a matter of fact I connected a -4 line to the stock return line. I also drilled out the stock fuel rail and tapped the end for 1/4" NPT so I could attached the Aeromotive FPR using -6 line...AND it saved me $120 or so by not having to buy those moster fuel rails.
Carry on!
Old Sep 12, 2002 | 10:05 AM
justinCO's Avatar
Default Re: Fuel system sketches (mplex2000)
I'm not using this setup yet, I posted this to get suggestive critisism such as yours I never thought of using the same size lines from the filter to the rail in the situation where using -8 feed from tank to the filter. Hmm, maybe I'll do that. As far as the return, I don't think there would be any advantage to going down to a -4 size, except saving money?? I can't see why it would hurt to have -6, I really dont' think it's that big of a deal on the return line.
Justin
[Modified by justinCO, 12:06 PM 9/12/2002]
Old Sep 12, 2002 | 01:34 PM
Smashback's Avatar
You're right, there would be no advantage function wise to using a smaller return. But it does save money, and like .05 pounds in weight savings!
Also, a -6 (or 3/8" in rubber hose) feed should be plenty for most Hondas...I can't remember the exact numbers but I would think that would supply enough fuel for at least 400 horses, probably more.
Also, not sure if somebody else mentioned this already but you can place that FPR inline between the tank and rail. It would save some money in hose and fittings and offer an alternate mounting location.
[Modified by mplex2000, 10:35 PM 9/12/2002]
Old Sep 12, 2002 | 02:30 PM
2000Accord5sp's Avatar
Looks like you need to use Visio to do your drawings.
Old Sep 12, 2002 | 03:10 PM
Smashback's Avatar
Default Re: Fuel system sketches (2000Accord5sp)
Huh?
Old Sep 12, 2002 | 03:20 PM
justinCO's Avatar
Well, I'm not planning on upgrading the fuel lines from the tank up until after I do a motor rebuild. For now they are staying stock, with exception to the lines between the rail/filter and rail/fpr.
Huh? The fpr *is* placed inline between the tank and rail as it is drawn. Or you talking about something else?
Visio shmisio I had to bust out my highschool taught drafting skills for this sketch See, highschool *does* help you in real life situations!
Justin
[Modified by justinCO, 5:21 PM 9/12/2002]
hybrid901
Jul 29, 2003 03:59 AM
Flip831
Dec 3, 2002 05:29 PM
B16bfannatic
Sep 5, 2002 11:57 PM
