DOHC ZC header fitment questions...
Old Jan 31, 2010 | 09:55 AM
JDMefHATCH7's Avatar
Default DOHC ZC header fitment questions...
im looking for a new header for my hatch cause my greddy header has a crack and the 2-1 piece was welded by previous owner
i got a DOHC ZC and im wondering if this ebay 4-2-1 header will bolt right on on my engine without any clearance issues with the front crossmember or anything...
http://cgi.ebay.com/ebaymotors/1992-...Q5fAccessories
also can anybody verify if the outlet size(to the exhaust) really is 2.5'' cause it says inlet and i dont wanna buy the wrong one
also if anybody knows where i can find any other D series header as long as it has 2.5'' outlet please let me know
Old Jan 31, 2010 | 01:23 PM
JOE BD-0's Avatar
Default Re: DOHC ZC header fitment questions...
found it for you.
https://honda-tech.com/forums/showth...t#post21938150
good luck
Old Jan 31, 2010 | 02:02 PM
i asked if anybody could verify me if the posted above ebay header has 2.5'' piping
or if anybody knows of any header that fit the DOHC ZC with no problems and has a 2.5" outlet for piping...
as im running an RSR EXmag that has 2.5'' all around and need to get rid of my cracked greddy header
thanks for the info though
Old Jan 31, 2010 | 03:58 PM
beansandrice's Avatar
That exhuast does not look like 2.5". Looks more like 2.1/4" and its not mandrel bent at all.
As far as the header down pipe you have posted no,,, it will not bolt up to the ebay header unless you get a dc clone.
you have to buy the ebay header and do that same crap they did to the dc header.
Old Jan 31, 2010 | 04:42 PM
the pic shows the cheap weld they did all the way to the muffler
i do not use that piping at all anymore im just showing why im not using the downpipe anymore on my RSR cause i cant since its welded
im not planning on using greddy header with ebay downpipe nor ebay header and grewddy downpipe(piece of **** shown in the pic)
im tryna use a whole new header (with downpipe) as long as it bolts up good on my ZC with no clearance problems and has a 2.5"
thanks for the info...
anybody wanna tell me if thats 2.5" outlet to piping? or anywhere else i should look for a 2.5" outlet header for a ZC (D series)
Old Jan 31, 2010 | 05:08 PM
looks like 2 1/4 bro. Most 4-1 headers are 2.5"
Old Jan 31, 2010 | 08:12 PM
know where i can find a 2.5'' outlet header?
Old Feb 1, 2010 | 12:56 PM
anyone?
i need a header asap
Old Feb 2, 2010 | 07:11 AM
jlicrx's Avatar
Kamikaze and Bisimoto both have 2 1/2" outlet
Old Feb 2, 2010 | 08:09 AM
90SICRX's Avatar
You can use any d-series header but you need to have it port matched to the ZC ports as that are slightly different.
Old Feb 2, 2010 | 04:48 PM
JOE BD-0's Avatar
Not sure, but it looks to me like all that is needed here is the top half of a dc 4-2-1 for D16A6. That piece should bolt right on to your existing hardware in the photo.
Like Jlicrx's info in the link, if you get the DC header for USDM D16A6, you should not need to port match your DOHC ZC at all, If I am correct.....more info....
Old Feb 4, 2010 | 02:40 PM
that above posted picture is NOT my exhaust setup is the piece of shxt welded piping the idiot did and fxcked up the lower(2-1) portion of the header besides the top part (4-2) is cracked
how much do these headers go for and are they still available or discontinued?
ALSO as far as the porting of the ports in the header...
is it a MUST or just better if done?
do I get this done at machine shop?
Old Feb 4, 2010 | 03:16 PM
It is not a "must" just matches the ports to the head.
Old Nov 16, 2012 | 10:51 AM
JimmyNeutron99's Avatar
i was also wondering where i can get a header for my dohc header i was looking on ebay but i have had bad luck in the past with ebay headers and they sucked big time im still looking for one i have oem now but want better
Old Nov 16, 2012 | 10:59 AM
24TEN's Avatar
PHANTOM MENACE
It's the same flange pattern as any of the 88-00 Civic D-series headers. Also it's the same flange and port pattern as the 88-89 Integra D-series header, not sure about 86-87 and don't want to assume but I'd guess it's the same as well.
rev_this
Dec 30, 2007 11:20 PM
1badrex
Mar 8, 2005 05:54 PM
civais
May 18, 2004 05:26 PM
jayjay
11
Feb 17, 2004 01:22 PM
GroundZer0
24
Jul 8, 2003 10:58 AM
