eg f22 mounts
What are the best mounts for the price to fit a jdm dohc f22b in to a 95 civic dx coupe? Hasport, Avid, innovate, hcp ect... also what do i need to do to wire up the the motor to the car, could i use a civic dx harness and delete the iabs?
heres my build link...http://cb7tuner.com/vbb/showthread.php?t=73927..it was an SOHC swap..i used the factory Ex VTEC harness..p28 ECU....hopefully thatll help you...had to re-drill the trans mount to work....
The axles I beleive will be the same axles that go with the corresponding mount kit...(you may want to double check here though, the accord intermediate shaft I think is different than the prelude)
Best of Luck!
