NEED HELP!!! Tranny (LSD) Question???
Old Sep 5, 2002 | 12:31 PM
BoostedAcura's Avatar
Default NEED HELP!!! Tranny (LSD) Question???
I really need a good answer to whether or not an LSD from a Type R tranny will fit into a LS Tranny. All are 94+ hydros. I've heard yes and no. I just need a good correct answer. Thanks guys.
Old Sep 5, 2002 | 12:41 PM
owen_the_soyboy's Avatar
Default Re: NEED HELP!!! Tranny (LSD) Question??? (BoostedAcura)
Not without other parts... like a different set of end bearings.... the bearings for a B16LSD tranny...
but this was covered in a different thread somewhere, maybe it is archived.
you cannot just slap it in to your ls tranny after removing it from an itr tranny.
you CAN swap the LSD between itr and gsr trannies though, I know from experience.
Old Sep 5, 2002 | 12:56 PM
Default Re: NEED HELP!!! Tranny (owen_the_soyboy)
does anyone know all the exact parts i will have to change out?? i did a search and have gotten so many mixed results. thanks
Old Sep 5, 2002 | 03:10 PM
sidan's Avatar
Default Re: NEED HELP!!! Tranny (BoostedAcura)
From what I have heard it will not work
But it may work if you change the final drive gear with a itr final drive you will also have to put new bearings and speedo gear on it
I ran into the same problem and that is what the guys at quaife told me but they couldn't guarantee
Old Sep 5, 2002 | 07:42 PM
Default Re: NEED HELP!!! Tranny (sidan)
hmmm, this must be the impossible to answer question...thanks for the help so far though
Old Sep 6, 2002 | 12:13 AM
ej1252
Mar 29, 2008 06:13 PM
Boostage
Jul 3, 2006 04:24 PM
Nextelbuddy
May 19, 2004 07:26 AM
K20EG
Oct 9, 2003 02:00 AM
cursED
10
Jan 1, 2003 09:38 PM
