tranny cases
I know the hydros are interchangeable, the B16 cables I've taken apart don't have the detent ball and spring with the 12mm that holds them in, whereas hydros do. Somone else would probably know better. Auto casing would not work on hydro. To original poster, make sure you use ITR shift forks. I just went to put GSR gearset in LS case with LS shift forks, 3-4 LS shift fork is too small to fit slider. I imagine ITR would be same scenario.
swaytec360
Dec 29, 2004 05:02 PM
