How to Make Your Car Last Twice as Long
Old Jan 30, 2010 | 05:53 AM
vinceiscoo's Avatar
Default How to Make Your Car Last Twice as Long
What Car Makers Don't Want You to Know
David Solomon, Nutz & Boltz®
One of the best ways to save money is to avoid buying or leasing a new car. Motorists can easily double or even triple the life spans of their present cars simply by performing proper maintenance, practicing good driving habits and avoiding the kinds of mistakes that send most cars to the junkyard.
Most Common Mistakes
Mistake: Failing to observe the "break-in" period. Drive gently during a new car's first 50 miles, and vary your speed for the first 500 miles of the car's life. Failing to do so results in improper seating of the piston rings, which leads to increased oil consumption throughout the life of the car. Also, change the oil promptly after the first 1,500 miles to eliminate bits of metal and grit found in a new engine.
Mistake: Making sudden starts and stops. Accelerating aggressively only to slam on the brakes at the next traffic light doesn't save time, but it does cause needless wear on your engine, transmission, suspension and brakes, and it wastes gas.
Better: Anticipate traffic patterns to keep your speed as constant as possible.
Mistake: Downshifting needlessly. In the early days of automobiles, brakes were so unreliable that prudent drivers always shifted into a lower gear when descending hills or approaching busy intersections. Today, brakes are very reliable and far less costly to repair than engine and transmission components.
Rule: Use engine braking only when descending a long, steep grade. At all other times, use your brakes.
Mistake: Driving hard with a cold engine. Engine wear occurs most swiftly not during high-speed driving but in the first moments after a car has been started, when the cylinders are starved for oil.
To avoid trouble: Before driving off, let your engine idle with your foot off the accelerator pedal for about one minute. Once you're under way, drive slowly and avoid using your heater and other accessories until the engine reaches its normal temperature, usually after about three minutes.
Special dangers: Accelerating briskly with a cold engine can cause the engine's head gaskets to fail. Premature use of accessories expedites wear of engine bearings.
Mistake: Shifting gears haphazardly. Manual transmissions cost less and are cheaper to maintain than automatics, if you learn proper shifting techniques. Picking too high a gear for a given speed "lugs" your engine. Picking an excessively low gear causes it to "overrev." Both waste fuel and damage your engine bearings.
Better: Shift so your speed remains between 2,000 and 3,000 revolutions per minute (RPM). Use overdrive settings only for speeds greater than 45 miles per hour.
Common problem: With many manual transmissions, shifting from neutral to first gear causes an audible grinding of the transmission's synchronizer rings.
Remedy: Avoid shifting directly from neutral to first gear. Instead, move the shift lever briefly into second, then shift into first gear. And never rest your hand on the shift lever or your foot on the clutch pedal. Use your right foot for both the accelerator and the brake. Use your left foot for the clutch.
Mistake: Driving with dirty and/or worn-out oil. For many motorists, oil maintenance means simply adding the occasional quart of 10W40. In fact, 10W30 offers far more protection against engine wear than 10W40.
By the time you're a quart low, it's time for another oil change. Change conventional motor oil once every three months or every 3,000 miles, whichever comes first.
Better: Switch to synthetic oil. It costs a few dollars more but offers superior protection and allows for extended oil changes.
To keep oil clean between changes, select the biggest oil filter that will fit. Most cars come equipped with a short filter but will accept either a short or a tall filter. The tall one always provides better filtration.
If you live in a dusty environment, installing a bypass oil-filtration system provides an extra measure of protection without voiding your car's warranty. Cost: About $80 plus labor.
Switch from a disposable pleated-paper air filter to a reusable wetted-foam filter. Cost: $20 to $40. If not, help lock out dirt by applying a thin layer of grease to the seal between the filter and the filter housing.
Avoid oil additives. Despite testimonial claims, they neither reduce engine wear nor boost performance.
Mistake: Driving with dirty fuel. Clean fuel is essential for long engine life. Replace your fuel filter every 24,000 miles or two years, whichever comes last. Cost: $12 to $50.
In either case, stick to the recommended fuel. Using regular gas in a car designed to run on premium causes "knocking," which can quickly destroy the engine. Using premium gas in a car designed to run on regular wastes gas and money and causes drivability problems.
If your car has fuel-injection, never let your tank drop below one-quarter full. Cornering on an almost-empty tank can momentarily disrupt the flow of fuel to the fuel pump, shortening its life.
Mistake: Failing to guard against weather damage. To reduce exposure to sunlight and environmental threats, keep your car garaged or at least covered. If your car must remain outdoors without a cover, put a dashboard-protecting sunscreen in your windshield and park so that the car faces a different direction each day. This helps "spread out" sun-induced damage, such as a cracked or faded interior. Use silicone spray twice a year to preserve weather stripping and rubber surfaces.
Mistake: Ignoring your antifreeze. Antifreeze not only keeps your car working in cold weather but also helps prevent rust and corrosion. For optimal protection, use a 50-50 antifreeze-water mix.
Important: Use distilled water, not tap water. Change the fluid every two years or 24,000 miles, whichever comes first.
Better: Install the new Dexcool antifreeze, which is good for five years or 150,000 miles.
Mistake: Overtightening the lug nuts on your wheels. Though it sounds trivial, improperly tightened lug nuts or bolts represent a big source of trouble for car owners. Too much lug-nut torque, and your brake rotors will warp and cause your brake pedal to pulsate. Too loose, and your wheels will not be securely attached.
Problem: Many mechanics tighten lug nuts with air wrenches, which are notorious for overtightening.
To avoid trouble: Get your own torque wrench. Cost: $15. Every time your wheels are removed for maintenance, use the wrench to check the torque readings on your lug nuts against your owner's manual or the specs from your tire dealer. Do this before leaving the service garage parking lot.
Mistake: Failing to perform "hidden" maintenance tasks. While owners' manuals usually specify how and when to perform the most crucial maintenance tasks, they often provide incomplete information about other key tasks.
Examples: Manuals typically say nothing about brake fluid, which should be changed once every two years or 24,000 miles, whichever comes first. This is especially true of brake fluid in antilock systems.
Power-steering fluid should be changed every three years or 36,000 miles, whichever comes first. Timing belts should be replaced every 60,000 to 90,000 miles, and timing chains every 100,000 miles to 150,000. miles.
Without regular use, certain systems quickly fall out of adjustment.
To avoid trouble: Run your air conditioner and your defroster at least once every two weeks. Release and reapply the parking brake daily/weekly. Applying the parking brake keeps a car from rolling away and also keeps the brake itself from "freezing up" or falling out of adjustment. Operate your antilock braking system monthly. Ask your mechanic how to test the ABS safely.
Mistake: Failing to recharge or replace an old or weak battery. Besides increasing the risk of leaving you stranded, a weak battery causes wear on the alternator and the starter. Both need a good power source to operate properly.
To avoid trouble: Replace your battery six months before it is due to expire. Check the date on the battery's sticker. Choose the biggest, most powerful battery that will fit under the hood.
Mistake: Rustproofing your car. New manufacturing techniques and materials mean that rust is no longer the problem it used to be.
After-market or dealer-applied rustproofing treatment is unnecessary, costly and, in many cases, can void your car's rust warranty.
Old Jan 30, 2010 | 05:56 AM
vinceiscoo's Avatar
Default Re: How to Make Your Car Last Twice as Long
thought this was cool and might help some ppl!
Old Jan 30, 2010 | 09:19 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Most of it is good, although common knowledge to many car enthusiasts already.
However, a few of those are somewhat myths, questionable, or flat-out wrong, at least for Hondas.
There has been evidence that running a car hard for the first few minutes after building or re-building actually helps rings seat BETTER.
There is no need to let the car warm up for even a whole minute. 20-30 seconds is sufficient, as long as you're easy on it until it does warm up fully.
I don't like articles that just make the blanket recommendation of something specific like 10w-40 motor oil. Most Hondas require 5w-30 or 5w-20 on newer ones with tighter clearances. For any car using 5w-30 or 10w-30, switching to 0w-30 will help reduce cold start-up engine wear (thinner when cold).
Synthetic oil can help, but it's not totally necessary. My car has 287,000 miles and has used conventional most of its life. However now I'm using Mobil1 0w-30 synthetic, changed every 5K-6K miles (about twice a year for me).
Not so sure about changing to a taller filter. A taller (larger) filter reduces oil pressure, which could be detrimental to some cars that rely on oil pressure for things like VTEC operation.
Antifreeze - NEVER, EVER, EVER use Dexcool in a Honda cooling system, unless you want a radiator with sludgy insides. Stick with Honda coolant or Prestone green coolant. I've been using Prestone (regular mixed with distilled water and pre-mixed) since 2001 and never had any problems. My current radiator has been in the car nearly 6 years now and is also doing great.
You can't really use a torque wrench to check lug nut torque if they're tighter than spec, especially not a $15 one. What's better is loosening them yourself with the tire iron and then re-torque with the torque wrench. Or just use the torque wrench in the first place if doing your own maintenance.
While it appears to be a good article, someone without any automotive knowledge could very well do something bad to a Honda or other make car by following everything listed.
Old Jan 30, 2010 | 09:36 AM
Gamerchiq's Avatar
So how are the "newer" people to the car scene supposed to tell the difference between the good info and the misleading info in this post?
Old Jan 30, 2010 | 11:47 AM
Hatorade's Avatar
owner's manual & Helm's.
All the info you need. Internet is for techniques/experiences, use HONDA for facts/specs.
Old Jan 30, 2010 | 12:12 PM
lucelukeEH2's Avatar
Agree Totally with Patrick, ALSO,:
Quote: "Mistake: Rustproofing your car. New manufacturing techniques and materials mean that rust is no longer the problem it used to be.
After-market or dealer-applied rustproofing treatment is unnecessary, costly and, in many cases, can void your car's rust warranty. "
NOT rustproofing a Honda, at least in Canada, well maybe with the exception of the Lower Vancouver area IS A SHEER falsity, Fallacy! From personal experience with Honda's and Toyota's, almost a total of fourteen of them now, Over twenty years, both my brother and myself have Proven to ourselves that a good quality, reputable rust inhibitor such as (thankless vouch) Rust Check or Krown, WORKS in literally stopping rust production and propagation from taking place, and has totally helped us in keeping our Honda's and Toyota's lasting longer and looking better, at least in Northern Canadian environments. IT WORKS!!!!! These products, or any of the good/reputable ones like them, have lengthened the life of our cars by between 5 to ten years and are Still able to sell our vehicles for good money when we're finished with them.
Old Jan 30, 2010 | 12:15 PM
Hatorade's Avatar
^^ true true...i'd say for 2001+ designs, no rust proofing is needed. my 96 integra is from texas. its been in Canada for a year and there is already rust on qp.
Old Jan 30, 2010 | 12:46 PM
Peter100's Avatar
really? I didnt know that,why does that happen only in first ?
Old Jan 30, 2010 | 02:03 PM
Goldenls's Avatar
i was wondering also
Old Jan 30, 2010 | 02:14 PM
Hatorade's Avatar
and does it have to do with how you almost never downshift into 1st??
Old Feb 2, 2010 | 05:07 AM
Community Builder
lol my car doesn't do that, never has done that. 287K original miles on the transmission.
Old Feb 2, 2010 | 09:14 AM
91akira's Avatar
My Manual teg was running pennzoil for the tranny for a long time. It occasionally grinded on 2nd. After switching to honda tranny oil, the grind totally disappeared.
I didn't believe some of whats said in that article.
Old Feb 2, 2010 | 11:20 AM
G0NZ0's Avatar
Good read.
Most I would chalk up to common sense but after living with a few women and being the mechanic of the house it's sad to say that most women, or men who don't work on their own cars, really should read this.
Old Feb 2, 2010 | 11:23 AM
G0NZ0's Avatar
I think its a good article for people with little knowledge as used in the sense to try to teach them and help them understand good driving habits and just being more aware as to what wear and potential damage to look out for and not take for granted
I don't think people with little knowledge should start servicing their own vehicles and poking around in places they're not familiar with just because they read this though.
Old Feb 2, 2010 | 11:51 AM
Gamerchiq's Avatar
first gear doesn't have synchronizers in it like the other gears do, at least on b series anyways. and whether you hear it or not it does grind
T3KNiQe
Honda Civic (2006 - 2015)
37
Jul 27, 2009 09:00 AM
mustardgirl100
Honda S2000
Apr 9, 2006 12:26 PM
Azcheron
Dec 11, 2005 08:04 AM
RSXisS
26
Feb 28, 2005 04:09 PM
blackgrrl23
Jan 14, 2005 11:09 AM
