Am I having a leak?
Looks like you missed during an oil change, added too much oil, or your oil cap doesn't have the o-ring.
Clean it all up, and run the car at idle and check where it's coming from.
because the oil starts getting churned up and becomes aerated. this in turn changes the oils viscosity and prevents it from lubricating important things like bearings properly. having way too much oil will spin a rod bearing, but just a little bit over generally isn't going to cause an issue.
