sohc help
dizzy mounting points are the same for an obd0 si and a y8. i dont think a pr3 ecu will work i with the obd0 dizzy though. i know for sohc obd0 dizzy has different amount of teeth for crank sensor so you cant mix and match. obd2 n 1 u can switch w each other though.
as long as the dizzy/ecu are the same OBD electrically they'll work. Also OBD1 or OBD2 dizzy will work either OBD1 or OBD2 ECU. I ran a Z6 w/ 89 Si distributor and OBD0 PR3 ecu for a while with no problems, just a little rich. Now will the B16 dizzy bolt up right, no.
gezzuzz
Mar 12, 2005 11:01 AM
Maddox
10
Apr 11, 2004 11:24 AM
