will 95 integra dash work on 96 integra?
i have two integras and my 95 has black interior and my 96 has brown interior.... can i swap out the dashes and all the interior? what will i need to do in order for it all to work properly? my main concern is the cluster and heater controls and all that stuff
i hope so, i already tore the 96 apart, lol everything is outta the inside. and then i was thinkin.... FAUCK the 95 is obd1! and the 96 is obd2! dammiT!! lol, but then i was like well hopefully the dash and all is the same and just the engine harness and motor stuff was different. but what about the cluster? i heard that if you want to use a 99 gsr cluster in a 96 you have to change the green thing on the back of the cluster.
Im not changin the ecu and have the airbags deleted with a tray, but my main concern is the cluster, is 95 plug in play with a 96?
i didnt work... the grey plug that goes near the fuse box is different, so i swapped out the wiring and it all work good now. dam black on black on black is freshhh lol.
I did this to my integra. I have a 96 and swap a 95 blk dash into it and everything worked fine. As long as you plug everything back correctly you'll have no issues.
well my car is a 96 rs, and i got the interior from my other 95 gsr integra, so i dunno if it was different cuz it was a gsr but the big grey plug had a few extra wires, so the plug was to big to clip into eachother.
.Hookedonhatch.
Jan 18, 2007 08:58 PM
