97gsr PARTOUT/98-01 front/ ign with TypeR key/ green/tan/ clean
Old Jan 28, 2010 | 04:55 PM
lthao61's Avatar
Default complete 97 GSR parts list
updated 01/31/2010:
1997 Acura Integra GSR 2door/coupe/hatch whatever
101k miles
title in hand
green exterior
tan interior
only flaw is the driver's rear in picture
KYB Gr2 with Eibach Spring suspension
OEM ign w/ TypeR key (no play)
updated list of parts and Items gone and sold
itemsor GONE
motor swap/trans/shift linkage/ axles:::::::::: ECU is still available
L&R front knuckles/ brakes/ calipers
F&R sway bars
GSR BUTTERFLY RIMS
front seats
shift ****
radiator
ac compressor
items PENDING: (front end is pending to ****tegradriver****)
lmk what you're interested in. PM me with zip code for shipping rates. will only ship to the LOWER 48 states!!!! car/parts is located in Sacramento, CA for pickup. i know im forgetting alot of things, but PM me or email me for more info or pics.
LTHAO61@HOTMAIL.COM
PM me with zip code for shipping rates...HERE'S the LIST
sunroof cover 10 plus shipping
driver side door panel 20 plus shipping **no switches, tweets, bezels, or handle
pass. side door panel 20 plus shipping **no switches tweets or handle
ignition switch with harness and with OEM Integra Type R key 60 plus shipping
steering column cover (attaches together) 10 plus shipping
turn/headlight combo-switch 15 plus shipping
wiper switch 15 plus shipping
dimmer switch 5 plus shipping
5 speed conversion with switch, pedal assy., hardlines, master and slave cyl 65 plus shipping
driver side kick panel 10 plus shipping
passenger side kick panel 10 plus shipping
wiper delete plug 5 plus shipping immaculate condition
antenna delete plug 5 plus shipping immaculate condition
black rear cargo cover CLEAN missing 1 tab underside 15 plus shipping
rear hatch shocks L&R pair 20 plus shipping perfect working condition
BARE pass door NO WAVES OR DENTS **no mirror, panel, glass, handle 50 NO SHIPPING
BARE dr. door NO WAVES OR DENTS **no mirror, panel, glass, handle 50 NO SHIPPING
center console great condition no ash tray/lighter assy or shift boot cover 20 plus shipping
shift boot with cover 15 plus shipping +15 for leather
rear seats PERFECT condition no holes or scratches comes w/ trunk carpet 35 NO SHIPPING
4 KYB GR2 struts w/ Eibach Springs PERFECT RIDE 1.75f/1.5r **150 w/ stock trade or 230 without trade
Sunroof assymbly w/ glass 60 plus shipping comes with switch
pass side rear quarter glass 20 plus shipping no molding +5 with
driver side rear quarter glass 20 plus shipping no molding +5 with
gas door with cable 15 plus shipping
front wiper assembly with blades, motor, arms 30 plus shipping
front windshiel cowl 10 plus shipping
L windshield molding 10 plus shipping
R windshield molding 10 plus shipping
top windshield molding 10 plus shipping
rearview mirror 10 plus shipping not cracked comes w/ screws
driver side outer door handle 20 plus shipping comes with lock
pass side outer door handle 20 plus shipping comes with lock
driver side mirror POWER 20 plus shipping
pass side mirror POWER 20 plus shipping
GSR cluster no outer bezel small hairline 50 plus shipping +10 with bezel +5 with plugs
driver's airbag with wheel 65 plus shipping NO CRACKS AT ALL
pass side airbag 40 plus shipping NO CRACKS AT ALL
driver side window master switch functional(works) 25 plus shipping w/ bezel
pass side window switch works 15 plus shipping w/ bezel
driver side inner door handle w/ lock switch and bezel 20 plus shipping
pass side inner door handle w/ lock switch and bezel 20 plus shipping
tweet set (works) 25 plus shipping
*****PLEASE ASK FOR PICS*****ALL ITEMS ARE IN WORKING ORDER, NOT BROKE!!!!!
dr side door actuator assy. 15 plus shipping
pass side door actuator assy 15 plus shipping
dr. side window motor 30 plus shipping comes with regulator
pass side window motor 30 plus shipping comes with regulator
Left and Right rear disc CONVERSION comes with cables, and brake lines BAD LEFT BEARING ONLY 100 NO SHIPPING
Left and Right civic knuckles with rotors, calipers, studs, brake lines 50 NO SHIPPING
rear civic lower control arms 10 each plus shipping
front civic lower control arms 15 each plus shipping
Power steering rack 50 NO SHIPPING no tie rod ends +15 for both +40 subframe
power steering pump with hose 50 plus shipping
tie rod ends 15 plus shipping
front upper control arm 10 each plus shipping
steering column (TILT) 25 plus shipping **no switches, locks, covers
ABS sensors 15 each plus shipping
engine bay fuse box cover 5 plus shipping
lower drivers panel with coin box and fuse cover 15 plus shipping
window visors 10 each plus shipping
interior clock (works) 15 plus shipping
hazard switch 5 plus shipping
rear defogger switch 5 plus shipping
glovebox 10 plus shipping +15 with rear bracket, screws, and shock assy.
evaporator CORE 15 plus shipping +10 for whole assembly
blower motor ONLY 10 plus shipping +10 for whole assembly
radiator fan immaculate condition 10 plus shipping
cruise actuator w/ cable 10 plus shipping
Old Jan 28, 2010 | 11:17 PM
lthao61's Avatar
Default Re: 97gsr PARTOUT/98-01 front/ ign with TypeR key/ green/tan/ clean
ttt
Old Jan 29, 2010 | 08:20 AM
lthao61's Avatar
ttt
Old Jan 29, 2010 | 09:57 AM
tegradriver's Avatar
Hey man, so what parts are left?
Old Jan 29, 2010 | 09:05 PM
ej8slim's Avatar
Do you have the cat for the car?
Old Jan 30, 2010 | 02:05 PM
lthao61's Avatar
Cat is being used for smog
Old Jan 30, 2010 | 06:55 PM
lthao61's Avatar
top
Old Jan 30, 2010 | 09:25 PM
I'm going to see this car tomorrow hopefully
Old Jan 31, 2010 | 03:16 PM
lthao61's Avatar
updated
Old Jan 31, 2010 | 03:37 PM
JDMInteg96's Avatar
ttt
Old Jan 31, 2010 | 05:52 PM
lthao61's Avatar
thanks for the BUMP
Old Jan 31, 2010 | 07:42 PM
lthao61's Avatar
ttt
lthao61
Northern California (Sales)
52
Apr 8, 2010 01:19 AM
lthao61
Feb 26, 2010 07:52 AM
spAdam
Feb 1, 2010 07:29 AM
lthao61
Jan 26, 2010 06:07 PM
