97 accord 4cyl ex clutch master cylinder Help
Old Jan 28, 2010 | 04:39 PM
jdubbs99's Avatar
New User
Default 97 accord 4cyl ex clutch master cylinder Help
I am trying to remove the clutch master cylinder and for the life of me i can't figure out how it is possible to remove the 12mm nut on the inside under the dash close to the driver side fender.
its one of 2 that hold the cylinder on. it is tucked in a corner with the clutch pedal and the side of the car blocking everything i have tried everything i can think of wobble sockets, a socket with a universal joint and extension but cant get anything to get in there that will work .
Any suggestions would be appreciated thanks
Old Jan 28, 2010 | 04:52 PM
davey5300's Avatar
Default Re: 97 accord 4cyl ex clutch master cylinder Help
That nut really sucks. Take out the relays on the fuse box next to you (just remember which one goes where) and use an relatively long extension.
Old Jan 28, 2010 | 04:57 PM
ncoutlaw's Avatar
i used two 12ince extensions and an swivel at the socket that worked for me
03djmAccrd
Jul 8, 2010 01:37 AM
vodkaTM
Dec 11, 2009 11:56 AM
vodkaTM
Nov 28, 2009 04:15 PM
rollercosta123
Jan 2, 2006 02:11 PM
jdmcivicferio
Apr 9, 2004 09:44 PM
