HEY B18C5!-------my secondaries not working so what do i have to hook up 92civic hatch SI w/ 99gsr s
Old Sep 5, 2002 | 10:22 AM
jwilsonguy's Avatar
Default HEY B18C5!-------my secondaries not working so what do i have to hook up 92civic hatch SI w/ 99gsr s
hey B18c5 please respond thanks....the rod dosnt move past 6000 or at all.....
thanks again...
Old Sep 5, 2002 | 10:26 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: HEY B18C5!-------my secondaries not working so what do i have to hook up 92civic hatch SI w/ 99g
Last time I checked, the IM function was still working.
Edit: You`re a newb and can`t do it haha
[Modified by vtecvoodoo, 7:26 PM 9/5/2002]
Old Sep 5, 2002 | 10:29 AM
One Bad GeeSeeR's Avatar
check the pin out to the ecu a20 i believe, when i did my swap in a 93 cx i switch the pin outs from a17 to a20, try that i hope i got the pin outs correct.
Carlo
Old Sep 5, 2002 | 10:44 AM
oldB18EF's Avatar
Search for IAB...theres a thread in Hybrid which helped me get mine working.
Old Sep 5, 2002 | 09:13 PM
jwilsonguy's Avatar
ya it says A17 pin but tried it and every time i plug back in the A plug to the ecu it doesnt get voltage from that wire....but when the plug is out and just A17 wired to pin there is voltage and secondaries still not working...?
A20 is for evap purge selonoid
Old Sep 5, 2002 | 09:24 PM
oldB18EF's Avatar
What I did-
I did not have a PNK/BLU wire, just a RED wire at A20. I tapped into this RED wire, and ran it to A17.
Find the bell looking thing, drivers side on the intake manifold...look underneath...while the car is running take the vaccum hose off or squeeze it or whatever, the lever underneath should move. Have someone watch it while you start the car, it should move when the car is started. Hopefully this helps.
Old Sep 5, 2002 | 10:44 PM
jwilsonguy's Avatar
Ya i tried putting the wire directly to A17 pinout and secondary doesnt move (IAB diaphram).....
so splice the Red A20 and connect the pink/blue from the connector/engine harness directly to Red A20??? therefore still leaving A17 blank no wire connected...
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
pnwjdm
Jan 12, 2013 05:34 AM
Rand The Man
Oct 12, 2010 09:00 AM
Civic Hx-T
May 12, 2004 09:21 AM
b16ahybrid
Mar 7, 2004 08:52 PM
