94 integra going turbo
Hi guys. i am a newbie to this site, so dont flame on me if i am posting in the wrong section. i read the posting rule already.
i pick up my 94 integra ls from fresno cali in jan 2009. its complete stock with no mods at all. i dd it for 6 months and didnt like the power at wot. so i have my spare 96 gsr motor that i swap into it to make a fun for the weekend. motor was bolt on with spray. i had fun with it for about a week and decide that i wanted more power. so now i am where i am going turbo.
some stuff i change was put on the lips, rear spoiler, rota slips, lower on kyb shock and no name adjustable coil, front and rear camber kit, complete sturt bar from top to bottem at front and rear. amber corner lights and just other little stuff.
gsr motor put in. (nitrous still hook up)
obx gt40r bb turbo
block guard
new bearing and arp head stud
head gasket set.
whole kit
parts going into the built and cost
turbo kit with gauge cost me $900.00
obx gt40r bb turbo $950.00
Head gasket set $45.52
Arp head stud $134.00
Blox block guard $86.40
ACL bearing $53.33
Hondata s300j $650.00
Walbro 255 fuel pump $90.00
JE pistion/Eagle rod $744.00
Prescion 1200cc injector $291.00
Still need some more parts then i should be taking the motor apart and putting everything in.
next on my list is.
AEM wideband
Built the Head
Maybe sleeve my block
Upgrade Axles
Put motor together.
obx gt40r bb turbo
block guard
head gasket set.
whole kit
ACL bearing $53.33
next on my list is.
AEM wideband
Built the Head
Upgrade Axles
Put motor together.
so the valve and spring wont flow? yes the t4 turbo will bolt up with this manifold because the manifold is already custom cut and welded with a t4 plate. i already try bolting it up also and it fits without rubbing on the block or front frame.
Interesting that it doesnt rub with that manifold. Anyway, you should have no issue with valve float unless you plan on revving past redline or push some extreme amount of boost. Most likely the sleeves will give out before you float a valve.
yeah took a while to weld up the manifold to fit. you want to i can take some photo and show you how its welded up. the car will be only going to 8200 rpm. trying for 20psi if it can hold on a good tune.
Interesting, everything looks good though. You might hit a limiting factor with that manifold, but you should still be able to get 300-350whp out of it. Seems like my cast manifold like that ran out of gas around 330whp. Given I could've leaned it out and gotten 350-375 out of it, but I didnt care to do that. Good to see you have the S300 though.
Have a pic of the turbine (exhaust side) wheel?
Im not bashing, but it seems like you put a lot of money into your turbo and just used whatever manifold you could find. I had a log on my first car and very quickly wished i had gone with a nicer manifold. A good manifold will help a shitty turbo work better, but a bad manifold will hinder everything
You should read through the Forced Induction forum, namely the FAQ (at the top of the forum page) and make sure you're not making any of the cardinal "nOOb" errors in your build. Good luck! If you need any help, you can feel free to PM me any questions. I have built several turbo setups for myself and others and would be able to guide you in the right direction.
