94 integra going turbo
Hi guys. i am a newbie to this site, so dont flame on me if i am posting in the wrong section. i read the posting rule already.
i pick up my 94 integra ls from fresno cali in jan 2009. its complete stock with no mods at all. i dd it for 6 months and didnt like the power at wot. so i have my spare 96 gsr motor that i swap into it to make a fun for the weekend. motor was bolt on with spray. i had fun with it for about a week and decide that i wanted more power. so now i am where i am going turbo. some stuff i change was put on the lips, rear spoiler, rota slips, lower on kyb shock and no name adjustable coil, front and rear camber kit, complete sturt bar from top to bottem at front and rear. amber corner lights and just other little stuff. picture http://i915.photobucket.com/albums/a...DSC03852-1.jpg http://i915.photobucket.com/albums/a...DSC03857-1.jpg gsr motor put in. (nitrous still hook up) http://i915.photobucket.com/albums/a...r/DSC03861.jpg obx gt40r bb turbo http://i915.photobucket.com/albums/a...r/DSC06168.jpg block guard http://i915.photobucket.com/albums/a...r/DSC06169.jpg new bearing and arp head stud http://i915.photobucket.com/albums/a...r/DSC06170.jpg head gasket set. http://i915.photobucket.com/albums/a...r/DSC06171.jpg whole kit http://i915.photobucket.com/albums/a...r/DSC06172.jpg parts going into the built and cost turbo kit with gauge cost me $900.00 obx gt40r bb turbo $950.00 Head gasket set $45.52 Arp head stud $134.00 Blox block guard $86.40 ACL bearing $53.33 Hondata s300j $650.00 Walbro 255 fuel pump $90.00 JE pistion/Eagle rod $744.00 Prescion 1200cc injector $291.00 Still need some more parts then i should be taking the motor apart and putting everything in. next on my list is. AEM wideband Built the Head Maybe sleeve my block Upgrade Axles Put motor together. |
Re: 94 integra going turbo
anyone think the head can hold 18psi plus
very nice goodluck
The head wont be an issue. Also, are you sure that T4 turbo is going to bolt up to that manifold?
Originally Posted by nimixes
(Post 41414693)
very nice goodluck
Originally Posted by 95 integra
(Post 41414711)
bump
Originally Posted by Hawjap1gsr
(Post 41416232)
so the valve and spring wont flow? yes the t4 turbo will bolt up with this manifold because the manifold is already custom cut and welded with a t4 plate. i already try bolting it up also and it fits without rubbing on the block or front frame.
u should hot tank ur motor and clean up the engine bay a bit before u put the motor back in :thumbup:
(Post 41433708)
Interesting that it doesnt rub with that manifold. Anyway, you should have no issue with valve float unless you plan on revving past redline or push some extreme amount of boost. Most likely the sleeves will give out before you float a valve.
Originally Posted by steveDC2
(Post 41433805)
BUMP+++++++++:drink:
Originally Posted by CRACKINVTEC007
(Post 41434136)
WTF? Bump? |
(Post 41435313)
WTF? Bump?
^lol
anyone seen obx bb turbo in use before? |
here goes a closer look at the custom mani and turbo together.
http://i915.photobucket.com/albums/a...r/DSC06492.jpg http://i915.photobucket.com/albums/a...DSC03846-2.jpg http://i915.photobucket.com/albums/a...DSC03847-2.jpg some more picture of other things http://i915.photobucket.com/albums/a...DSC04352-1.jpg http://i915.photobucket.com/albums/a...r/DSC06491.jpg |
havent heard of anyone putting an obx turbo in their car yet. let us know how it goes.
Interesting, everything looks good though. You might hit a limiting factor with that manifold, but you should still be able to get 300-350whp out of it. Seems like my cast manifold like that ran out of gas around 330whp. Given I could've leaned it out and gotten 350-375 out of it, but I didnt care to do that. Good to see you have the S300 though.
Have a pic of the turbine (exhaust side) wheel? |
Im not bashing, but it seems like you put a lot of money into your turbo and just used whatever manifold you could find. I had a log on my first car and very quickly wished i had gone with a nicer manifold. A good manifold will help a shitty turbo work better, but a bad manifold will hinder everything
Originally Posted by srok1
(Post 41444872)
(Post 41445288)
Originally Posted by Gamerchiq
(Post 41445417)
You should read through the Forced Induction forum, namely the FAQ (at the top of the forum page) and make sure you're not making any of the cardinal "nOOb" errors in your build. Good luck! If you need any help, you can feel free to PM me any questions. I have built several turbo setups for myself and others and would be able to guide you in the right direction.
Originally Posted by Schister66
(Post 41450090)
(Post 41434030)
yup. my motor is kinda trashy with wire everywhere and stuff like that. i will be cleaning it up and doing little wire tuck before everything goes back in.
