vafc question
after i installed my vafc, sometimes i keep throwing code 3 which is map sensor. all connections to vafc are soldered, just wondering if any of you guys have this same problem before.
this is on a 94 integra gsr.
well i've checked it several times, and its correct at first i thought the connection was intermitent, so i pulled it all off and resoldered it. It dont do it all the time, just on cooler nights when i'm in the higher rpm in third or fourth. When it does it, my afr's get super rich as low as 10.9's, then i shut off the car, turn it back on and it drives normal, if not it will run rich as long as i drive it. I'm kinda stumped, when its running fine afr is at about 13.1 all the way across, most fuel added is 8% between 6500 and 7k other spots are like 3-5%.
South Bay Surfer
Dec 24, 2004 02:15 PM
98civicEX
Jul 2, 2002 07:16 PM
