rear brake caliper
Old Jan 28, 2010 | 04:56 AM
1sikhatch's Avatar
Default rear brake caliper
ok heres da deal, my rear caliper took a **** n i need one asap and the only one i can find rite now is from a da, are they the same thing?
i have a 96 integra btw
Old Jan 28, 2010 | 05:52 AM
GagnarTheUnruly's Avatar
Default Re: rear brake caliper
IDK about that (although I'd guess they aren't the same), but have you tried rebuilding the caliper? If the pin is siezed you can usually get it out with PB blaster + elbow grease, clean it, and replace the boot and you're good to go.
Old Jan 28, 2010 | 08:09 PM
1sikhatch's Avatar
havent tried to rebuild it yet, but wats happening is wen i press the brakes the caliper stays with pressure then if i tap the caliper it releases
Old Jan 28, 2010 | 08:12 PM
I bet you've hot a hole in the pin boot and corrosion is starting to sieze it up. Pull it apart and have a look. Cleaning it and replacing the boot could save you some $$
Old Jan 29, 2010 | 04:43 AM
dothacker's Avatar
LOTS of $$
Tim2179
Jul 24, 2019 12:12 PM
91integra91
Aug 9, 2011 05:57 PM
integra97R
Feb 8, 2003 04:15 PM
mantic6t9
12
Jun 3, 2002 03:28 PM
Type-R 940
Mar 20, 2002 10:51 AM
