b16 head vs gsr head
ive heard from alot of guys that b16 heads are much better for boosted cars and have better airflow than gsr heads. Is this really true or just a myth? how much of a difference is there between the 2 and how much better is one or the other. im building a boosted ls/vtec and wondering if it is worth it to get rid of my gsr head and get a b16 head or just keep mine and be fine. just let me know what you think. thanks
They flow nearly identical. Don't buy the hype from newbies that dont know crap. I received a question just the other day asking if a GSR head would fit a LS block.....
From what i understand the 01 gsr cams were better, i have a set in my b16a +ctr pistons. but you already have the head, why ditch it for another. I say stick with the head you have.
yea i really didnt want to and wasnt planning to but i just wanted to know if there was that much of a difference between the 2 that it is worth switching. thanks
op should search harder.
https://honda-tech.com/forums/acura-integra-6/end-all-flow-chart-comparison-between-p72-pr3-heads-1767009/
if you scroll down a little you'll see the flow chart. they both flow about the same. but if you look at closely, the b16 has a even flow while the b18c goes up and down a little(maybe cause of the intake mani?).
https://honda-tech.com/forums/showthread.php?t=1767009
I'll eat my shoe if that dip even means anything. It could just be random variation. Bottom line is that flows of B16 and B18 vtec heads are essentially identical.
LOL yes, B18C5 has a B16 head with a mild intake port job. Not sure why they decided to use the B16 head instead of B18? IMO the reason B16 swaps are so popular is b/c that's how the ITR was done.
I have a ls/vtec and i used the b16 head and my buddy is running a gsr head and i beat him everyime, with the b16 head u will be looking somewhere around 196 hp with the gsr head only around 180, its not too big of a difference though.
Originally Posted by ronnyb
gsr has bad flow but the cams are bigger and b16 has more flow but the cams are smaller if you can get b16 with gsr cams that would be the best option.
As far as 196hp....that sure is an exact number. However, B16 head vs GSR with all other items being equal there is not a 15hp difference.
Ls vtec = ls bottom end b16 top end
Why use a ls bottom end? Simple it has a longer stoke than a gsr bottom end why is a b20 block better than a ls block it's because the b20 is a 84 mm but with the same stroke yes it's a bored ls same head same everything.. hope this helps
