RLCA question.
I'm getting ready to order my Function&Form Type-I coilovers and weaksauce has a special right now on them. You get free LCA's with any F2 coilover purchase. Now they only offer that free LCA in the EG/DC/EK chassis.
Which ones can I run properly? And how the hell are these supposed to be put on the CORRECT way.
EG/DC is the same dimensions as EF.
do you have to buy EG coilovers too?
but i would not install the control arms. just sell them to the next chump. theyre not an improvement over stock, will probably wear out faster than your old stock ones.
Becareful to make sure you get coilovers for an ef not and eg. The coilovers in the rear will bolt right up with no issues. The fronts are a different story. The big difference would be the strut forks on the front the eg shocks are a bigger diameter ten the Ef's so you would need to get a set of eg ones to make the eg coilovers work.
id say go with progress too.
