Code 14 crx hf
Old Jan 27, 2010 | 04:50 PM
kevcha711's Avatar
Default Code 14 crx hf
Ecu is throwing code 14 anyone with exp or good adivice on what I should replace clean or fix to get this fixed
Old Jan 27, 2010 | 05:03 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Code 14 crx hf
code 14 is EACV.. is your car an Si or Dx?
first locate it and make sure it is plugged in..
If so,pull the hazard fuse under the hood to reset the ecu
and see if the code returns..
If you have removed the engine/wiring harness
you may have the plugs mixed up..
Old Jan 27, 2010 | 05:31 PM
kevcha711's Avatar
The car is hf model. I disconnected the battery and after reconnecting it the car doesn't want to turn on at all now
Old Jan 27, 2010 | 05:47 PM
kevcha711's Avatar
Ok after push starting it car turned on. Still with the same problems after resting the ecu
Old Feb 5, 2010 | 07:32 PM
EHSQUAD408's Avatar
im, getn code 14 to its not si but my engine is .. ther is one lose wire from the catalys im shure but its not throwing that code what chuld this be
Kris's turbo
Mar 24, 2012 02:42 PM
hatchyboy89
Oct 11, 2007 10:48 AM
pdiddyparsons
Apr 16, 2003 07:07 PM
Timmah!!
Sep 9, 2002 11:29 AM
