So i have a rod knock, now what should i do?
How many suggestions can there really be?
Rebuild your current engine
Get a new motor and swap it
Buy a new car
Walk or Ride a bike
Buy a new car
Walk or Ride a bike
depends on youre budget and goal is.
might be cheaper to buy a swap from h-motors or somewhere else.
or if you want to build for boost
send the motor out and sleeve it
it all depends on what you want.,,
well supposibly the guy who had the car before me put new rod bearings and rings.
he had to keep making it a point that he put chromoly rings. "chromoly rings, chromoly rings, chromoly rings. im like " i dont give a *****".
anyways, im thinkin if he did rebuild im thinkin i can get away with just fixing the problem, which is most likely either a rod bearing torque thing, or some **** with the wrist pin.
but on the other hand i was thinkin about putting low compression pistons in for a later planned turbo. how bad would that affect drivability without a turbo on. would i risk damaging the engine?
and even on another note, i would like gsr swap, but they want like 1800 for complete engine, with no ecu or harness, bout 1200 for just the long block.
so maybe ls/vtec?
i am on a tight budget. i can maybe squeeze out about $200 a month for the car.
what should i do?
so maybe ls/vtec?
what should i do?
so i have decided i am going to pull out the engine this weekend and fix the problem.
now please correct me if i am wrong but the rod knock could only be one of two things:
-rod bearing
-wrist pin
i will need IM gasket, EM gasket, head gasket, oil pan gasket, oil, and whatever is broken. let me know if im missing anything.
well now after i see this list of parts, im realizing that this is going to cost more than a pick and pull motor.
sigh.
-rod bearing
-wrist pin
sigh.
Crank and Rods are probably toast.....usually a spun bearing eats them alive. Long block B18A replacement will be cheaper, though probably have unknown mileage.
-rod bearing
-wrist pin
sigh.
-rod bearing
-wrist pin
sigh.
If you start a new Posting, send me or PM me a link.
GOOD lUCK
make sure to get the torque specs for all the internal parts
simple, call hmo and get a good low mile jdm ls or b20, and swap it out, keep your current motor for your future turbo build. Always easier to build a motor on the side, rather than have all the down time while your dd is sent out.
