Turned crankshaft pulley wrong direction...
Old Jan 27, 2010 | 10:06 AM
zsnarl's Avatar
Default Turned crankshaft pulley wrong direction...
I'm doing a timing belt change on an 96 Accord F22b2, and trying to set cylinder 1 to TDC.
I turned the crankpulley *clockwise* a few time and noticed that I was suppose to turn it *counter clockwise* did I fubar the valves?
when the camshaft pulley is aligned with the UP and side markings all lined up. How do i know I'm on cylinder 1?
Thanks
Old Jan 27, 2010 | 10:13 AM
dpetro1's Avatar
Default Re: Turned crankshaft pulley wrong direction...
highly doubtful that you messed anything up by turning the crank by hand regardless of direction.
if your crank pulley and cam gears are all lined up at the tdc marks, that means you are at tdc of cylinder 1, thats why the marks are there. sounds like you have everything good to go.
Old Jan 27, 2010 | 11:50 AM
alkoholikwun's Avatar
like stated above, everything is lined up, wont mess anything up.
Old Jan 27, 2010 | 12:15 PM
zsnarl's Avatar
Cool good to know.
Old Jan 27, 2010 | 07:14 PM
fleetw00d's Avatar
Just lining up the cam marks without paying attention to the TDC mark on the flywheel isn't enough. The TDC mark mark on the flywheel has to be lined up with the sight on the block for #1 to be at TDC, then "UP" on the cam should be up and the marks aligned with the head surface for the cam to be timed correctly.
foolsforever
11
Aug 9, 2018 05:08 PM
austinramsay
Jul 5, 2014 12:42 PM
snoochtodanooch
Jun 8, 2006 07:49 AM
valve79
Dec 25, 2004 11:22 PM
superfuji57
May 16, 2004 03:23 PM
