De-pin an obd1 to obd2 jumper harness...
Is it possible to de-pin the wires on the jumper side (not the ecu side connectors). I was looking and made an attempt but they are pinned a different style. The connector block isnt like OEM connectors where you can push down a tab and slide out the wire. It looks as if its a fixed opening where the terminal slides and "snaps in". Just wondering if it is possible, TIA.
So you want to remove a pin on the ECU block side.....not the side that plugs into the ECU, but the female side that receives the underdash ecu plugs?
If so, those pins pull outward....like pull from the female side. So if the wires are still soldered in on the otherside from the ecu plugs....not going to happen.
efhondaracer27
May 31, 2010 01:56 PM
216.226.142.95:27016
Jan 8, 2003 11:45 AM
