neep help on choosing a FMU for turbo LS
Old Jan 27, 2010 | 02:09 AM
20civic00's Avatar
Icon2 neep help on choosing a FMU for turbo LS
hey guys. I want to turbo my 98 ls integra. the motor was just rebuilt less then 10,000 miles ago. I want something really simple and reliable. I find plenty of decent turbo kits on craigslist, but I need help choosing a FMU. I want to run 8-10psi and 440 injectors and 255 fuel pump. t3/t04e turbo kit. would the blox FMU 12:1 be good enough? or should it be better overall to go with a chipped ecu and crome? or something along those lines? nothing too extensive. I was hoping to do this myself and not have to get it tuned at a shop. Is there a program or basmap i can download to a chiped ecu and tell it what i have and want for psi? so it can just b plug n play? whats the best way to go for this? sorry for the questions. just new to this. any help would b much appricated!!! i want to buy this ASAP
THANKS H.T.
Old Jan 27, 2010 | 04:24 AM
inspector01's Avatar
Default Re: neep help on choosing a FMU for turbo LS
Get a chipped ecu for sure, this isn't the 90s. If you want to do it yourself, get neptune, ectune, or hondata. If you are going to have a shop do it (which i would suggest if you don't know what you are doing), you would be fine with crome, but the others would be better.
Old Jan 27, 2010 | 04:34 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
+1
Old Jan 27, 2010 | 05:44 AM
Seraph0's Avatar
If you must run an FMU you won't want the 440s. And you'll want a 12:1. Don't forget to manually retard the timing too. And stay below 8psi.
Old Jan 27, 2010 | 09:37 AM
b18b1turbo's Avatar
^^^+1
Old Jan 27, 2010 | 09:57 AM
LS-turboner's Avatar
its really worth it to get Hondata or NepTune, get it tuned properly, then you can always upgrade your setup and retune later.
Old Jan 27, 2010 | 10:25 AM
welfarepc's Avatar
member since 2005, and thinks an FMU will be reliable? damn.
chip it.
Old Jan 27, 2010 | 10:27 AM
LSTurbo23's Avatar
your on the wrong path...you cant go cheap with a turbo system
alot of ym friends learned the hardway...if your gonna cheap out..cheap out on a manifold or turbo...you can geta way with that..but for Gods sake do not go a cheap route with tuning..that is the most essential and important part of a turbo system...you got alot of reading to do...hit up the stickys in this forum and read up...turbos fun but **** man...if you mess up the tuning..or your afr's...say goodbye to your motor
Old Jan 27, 2010 | 10:30 AM
jdm inc's Avatar
FMU=Junk!
Get the car tune! ie. crome or ectune ect!
it will be worth it!
Old Jan 27, 2010 | 07:29 PM
20civic00's Avatar
hey guys, thanks for the help. I actually do know a thing or two about turboing a car the right way, but not a cheap way. I actually have a ftw peakboost turbo kit with hondata s3oo and a fully build gsr that I am currently building, but what I didn't know is how to do a turbo set up in a "cheap" way if you will. i wanted something plug n play since it was just going to be on low boost and everyday driver. so i take it that i should still go with a chipped ecu and uberdata or crome. do u know of a place that i can send out the ecu and they can program it for me if I give them my setup and what boost i want? I'm just trying to save time and money on making a trip to the dyno on a car I really dont want to spend a lot of time and money on. thanks again for the help guys!
I've found turbo kits with everything but an fmu on craigslist between $500-$1000. I just need to know how to go about doing the fuel system. anyone have a complete kit they want to sell?!! haha
Old Jan 27, 2010 | 11:14 PM
jdm inc's Avatar
you could send your ecu to http://www.phearable.net/ i think john will set u up with a base map.
Old Jan 27, 2010 | 11:42 PM
20civic00's Avatar
do u know if they can program it for 8lbs of boost and whatever else I have done to the car and i can run it like that? or will i still have to go to a dyno and a tuner? I'll try giving them a call tomorrow. thank u
Old Jan 28, 2010 | 12:55 AM
blinx9900's Avatar
12:1 vortech FMU, factory cams, walbro 255HP fuel pump and you should be safe for 6-8psi. On an LS motor it will be plenty safe, it just won't make too much power, don't listen to haters saying your going to blow up your motor, it's simply not true, especially with the lower CR of the LS.
Old Jan 28, 2010 | 06:23 AM
DC4KiD's Avatar
This seriously makes you sound like you're cheaping out on the tune part of your 'build'.
The purpose of a basemap is to get your car started and driveable to a tuner, not to beat on.
Dude, since you're in NorCal, there are plenty of shops around here that you can just bring your car to; RedZone, DNR, CTR, DSR, Tech 3, etc...
Old Jan 28, 2010 | 01:04 PM
20civic00's Avatar
maybe I didn't make myself too clear. I'm building a different car,2000 civic with a peakboost turbo kit and fully built b18c1. I know how to build a turbo car the "right" way and thats what I'll be doing with my civic. but i just bought a 98 ls with a rebuilt motor and I wanted to do a turbo kit on low psi, but didn't want to spend a lot of money taking it to a tuner. it sounds like thats what i should end up doing anyways though. but i thought there was a place I could send my ecu and have it programmed for 8psi and have it sent back, avoiding having to drive to a shop and getting it tuned. but if thats what i need to to, then I will! thanks
Old Jan 28, 2010 | 01:34 PM
NonovUrbizniz's Avatar
Loved
No one can program an ECU correctly without tuning the car. Regardless of whether it's on FMU or EMS.
Old Jan 28, 2010 | 02:38 PM
blackmugensivic's Avatar
Apparently not if you're asking honda-tech which FMU to buy
Old Jan 28, 2010 | 05:47 PM
DC4KiD's Avatar
I know exactly what you were saying.
Just take your ECU to one of the shops listed so you don't have to deal with shipping/waiting time. Tell them your setup/what you have and they'll make a BASEMAP accordingly so you can actually drive your car. But if it blows because you were beating on it with a basemap, that's all your bad, Lol.
^This is correct, unless it's for identical setups. Even then, take it to a tuner because not all engines are the same, regardless if they have identical turbo setups.
Old Jan 28, 2010 | 09:18 PM
blinx9900's Avatar
Please tell me, do you have personal experience with FMU's? Or is all your knowledge on the subject based on reading honda-tech? Not being rude, just an honest question...
Old Jan 29, 2010 | 07:43 AM
Seraph0's Avatar
Listen to blinx and me and ignore the haters. You'll achieve your goals and enjoy your car just fine.
Old Jan 29, 2010 | 10:17 AM
I.C.C.'s Avatar
Thats crazy guys. So you are saying, just what you have listed, with stock map sensor, no way of tuning, and driving around with your timing retarded all the time, you'll be fine? That's crazy talk dude...
I have plenty of experience with them. The first turbo'd car I built back in 1999 consisted of a stock LS with a drag kit (turbonetics 57trim turbo), missing link, 12:1 fmu etc... Stock injectors couldn't handle more than 6-7psi of boost with the fmu, so I upgraded to dsm 450cc injectors, shortly after realized the car ran like dog **** without being able to control the injectors, and added an safc... Made right around 350whp on that setup, which at the time was unheard of around here... Then that bad *** FMU failed on me and cost me my engine!!! Bye bye ringlands!!! haha
First of all, those FMU's are very picky, and secondly, if you think about the fuel pressures associated with that, our cars fuel systems, even with RC or Precision or whatever injectors are not designed for that... Think about it like this, 40-45 psi base pressure + 12 psi increase per 1 lb boost @ 8 psi boost = roughly 136-141psi fuel pressure... Have fun with that!!
Old Jan 29, 2010 | 10:19 AM
I.C.C.'s Avatar
Listen to blinx and me and ignore the haters. You'll achieve your goals and enjoy your car just fine, until the fmu fails and it blows up, or a fuel line bursts and your car erupts into flames.
Fixed.
Old Jan 29, 2010 | 10:55 AM
Seraph0's Avatar
lol the first car I turboed back in 1999 was a DRAG3 on a 98 Integra GS-R too. The first four years and 50,000 miles it was FMU/check-valve setup. I'm still driving that car today.
I'm just saying if you must run an FMU setup for whatever reasons you have, this (me and blinx advice) is how you do it.
I think using an FMU based setup is better than the orig. question about whether to do this: "Is there a program or basmap i can download to a chiped ecu and tell it what i have and want for psi? so it can just b plug n play?"
Old Jan 29, 2010 | 11:54 AM
Turbo-LS's Avatar
FAIL !
Old Jan 29, 2010 | 05:21 PM
20civic00's Avatar
all this is really healpful, thanks for all the input H.T.
