what is the best brand of paint to paint engine blocks???
Old Jan 26, 2010 | 09:42 PM
mynameizstitch's Avatar
Default what is the best brand of paint to paint engine blocks???
what are some of the engine paint brand you guys recommend? ones i've heard of are duplicolor found anywhere and vht. i plan to repaint my engine block silver again to give it a fresh look.
Old Jan 27, 2010 | 09:31 AM
Default Re: what is the best brand of paint to paint engine blocks???
21 views and no repsonse. i guess right now im leaning towards vht.
Old Jan 27, 2010 | 11:11 AM
Spawne32's Avatar
anything you can find in the paint isle at your local autozone that is for high temps will work just fine. Hell i use high temp flat black with ceramic on my windshield wipers lol. one thing i do recommend and i dont know if you can find any for high temp, is use an etching primer. It helps the paint adhere ALOT.
Old Jan 27, 2010 | 11:47 AM
relicwelding's Avatar
go to any paint supply place..By paint supply i mean for automotive and ask them for etch primer..should be ok on the temp but any high temp paint in autozone will work just do a couple coats. good luck
Old Jan 27, 2010 | 01:22 PM
thanks i will get some etch primer also
Old Jan 28, 2010 | 05:57 AM
ken9's Avatar
I did go either Dupli colour or por 15
Old Jan 28, 2010 | 06:50 PM
uberEFtuner's Avatar
Do not use primer! Unless the can recommends it. Most high temp paints say to go directly on metal. CLEAN METAL
Old Jan 28, 2010 | 08:22 PM
thats what i was thinking also espeically since the engine gets really hot
Old Jan 28, 2010 | 08:54 PM
Spawne32's Avatar
thats why i said it would need to be a high temp primer, now i used regular old duplicolor etching primer on my valve cover and its just fine, but the block gets much hotter.
Old Jan 29, 2010 | 04:28 AM
precisionsc54's Avatar
I did my block with some stuff I got at Tractor supply it has ceramic in it and is good to like 800 degress. Had to spray over bare clean metal, then backed at 300 for an hr. Now its hard as a rock and looks very nice. It also said regular driving would cure it as well.
Old Jan 30, 2010 | 09:14 PM
thomkatt's Avatar
Seymour ftmfw
Old Jan 31, 2010 | 03:18 AM
cherroneballs's Avatar
I don't think I'd rattle can anything on my car, and deffinetly not a engine block. what are you gonna do when it starts flaking? just pull it out and touch it up. I would use a good steam cleaner, and if you have access to a sand or soda blaster I would skim blast it for a good profile, then go to a industrial paint supply store and see what they would recomend for the substrate and the conditions (heat, oils, ect.) but its not gonna matter what paint you use unless it's prepped correctly. I'd powder coat it personally, you have the heat and solvent resistance, and the chip resistance.
Old Jan 31, 2010 | 10:14 AM
I sandblasted the entire block and then sprayed and baked it. Havent had a single problem. Powder coat is nice just be sure to use high temp and have all work done after u powder coat it. Since the heat of baking could warp things
Old Mar 8, 2010 | 06:10 PM
eljah0426's Avatar
powder coat is no good for the block paint is porous allowing heat to leave powder coating is not trapping in heat you be the judge!
patotas
Paint and Body
Oct 7, 2009 09:31 AM
FishyMan
Paint and Body
Feb 28, 2009 06:17 PM
MAFDARK
Jan 26, 2007 05:52 PM
GarageTech
Jul 21, 2006 11:02 AM
RallyRedGT-V6
Jun 4, 2004 07:10 AM
