Bashed JDM 4-1 manifold, How to fix?
Old Sep 5, 2002 | 08:28 AM
migs's Avatar
Default Bashed JDM 4-1 manifold, How to fix?
How would you fix a bashed JDM 4-1 header. Lets just say the bottom 2 collectors have been reduced significantly. How would an exhaust shop fix this if at all possible?
Old Sep 5, 2002 | 08:30 AM
Rob :190:'s Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (Migs)
i've read before one way was to have a ball on a rod of some type, heat the **** out of the dents, and try to push them out from the inside through the collector. make any sense?
rob- who would rather just buy a new header
Reid's Avatar
Global Moderator
If it has been bashed significantly enough to the point where it's impeding flow, I'd send it to SMSP and ask him to cut the damaged portion on and weld on a better collector.
AssPenny's Avatar
drill a hole and use a puller like they do on body panels. Or cut out dent and weld new plate over it.
Old Sep 5, 2002 | 08:31 AM
migs's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (AssPenny)
Quick responses and thanks for the help.
[Modified by Migs, 9:33 AM 9/5/2002]
Old Sep 5, 2002 | 08:32 AM
Rob :190:'s Avatar
i wonder how much SMS would charge for something like that...
<-----'ground clearance edition mugen' equipped
Old Sep 5, 2002 | 08:34 AM
Majuniors_no_vtecfu's Avatar
if it bashed....means going to lose power get a new header
[Modified by Majuniors_no_vtecfu, 5:34 PM 9/5/2002]
Old Sep 5, 2002 | 10:44 AM
Nick248's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (Majuniors_no_vtecfu)
your torque must be crazy yO!
Old Sep 5, 2002 | 11:14 AM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
when I hit a rock in the road with mine it actually dented it so bad the metal split, in that case I had to have the damaged portion cut out and have a new section welded in... not to expensive once it was all said and done (around 50 or so dollars) but it was just a major pain in the a$$. In your case it seems like a small hole and a slide hammer should do the trick.
For the future I would suggest getting a skidplate or some sort of protection for it. I got mine after the accident from fastline performance.
let us know how it all turns out!!
later
matt
Old Sep 5, 2002 | 01:00 PM
Asahi's Avatar
OEM or DC?
Old Sep 5, 2002 | 01:02 PM
Reid's Avatar
Global Moderator
Default Re: Bashed JDM 4-1 manifold, How to fix? (champITR)
If you're going to make a skidplate, it'd be preferred to have it bolt to something other than the header itself.
What's going to prevent the skidplate from being smashed into the header?
Old Sep 5, 2002 | 01:14 PM
champITR's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (Reid)
in a severe impact... nothing; but for the everyday scapes and dings it works great. Something is better then nothing, I guess.
later
matt
Old Sep 5, 2002 | 02:26 PM
00MRSi's Avatar
I'd just go all out and have Dave make one of his custom headers..
If you damaged your OEM JDM 4-1 or DC 4-1 at least it didn't drain your pocket like the Jay DEE MM (Spoon, Toda, etc..)
Old Sep 5, 2002 | 05:06 PM
Lt. Dan's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (00MRSi)
how much does a header from SMSP run?
Dan
Old Sep 5, 2002 | 05:21 PM
disordeR's Avatar
it looks like the skid plate hangs a lot lower than the header... that true?
Old Sep 5, 2002 | 05:30 PM
baonest's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (disordeR)
u got the web addy to where u got the skidplate... i had it but cant find it anymore, ima go ahead and order one.
thanx
Old Sep 5, 2002 | 07:30 PM
Asahi's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (Asahi)
OEM or DC?
Curious which it was. Seen lots of DC's bashed due to clearance and no OEM's to date.
Old Sep 7, 2002 | 06:11 AM
champITR's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (baonest)
www.fastlineperformance.com
later
matt
[Modified by champITR, 10:14 AM 9/7/2002]
Old Sep 7, 2002 | 08:31 AM
Big Teggie's Avatar
OEM or DC?
Thats my dented OEM JDM 4-1.
Old Sep 7, 2002 | 08:40 AM
Daly's Avatar
New User
Default Re: Bashed JDM 4-1 manifold, How to fix? (Big Teggie)
holy $hit!!
Old Sep 7, 2002 | 08:50 AM
Maxi's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (Daly)
I banged up my Spoon header pretty good...wish that Fastline plate fit it, but apparently it's for 98+ JDM ITR headers only. Doh...
[Modified by Maxi, 9:51 AM 9/7/2002]
Old Sep 7, 2002 | 12:02 PM
champITR's Avatar
damn man.... mind if I ask just what the hell you hit?? it looks like you were jumping the car or something and bottomed it out!!! OUCH!!
later
matt
Old Sep 7, 2002 | 02:34 PM
Larkin W.'s Avatar
OEM or DC?
Ohhhhhhhh Snap!!!
Old Sep 7, 2002 | 02:49 PM
2lowintegra's Avatar
Default Re: Bashed JDM 4-1 manifold, How to fix? (EbboyPSi)
Old Sep 7, 2002 | 02:52 PM
xtrafastcivic's Avatar
reid do you know the bed of nails trick???
you know the one where a guy lays down on a bed of nails and have ppl stand on him... do you know how that works well the skidplate is kind of the same thing..fastline does say that these plates are very strong....
