No Power...
Old Jan 26, 2010 | 07:36 PM
guitarguru87's Avatar
Default No Power...
Sorry I've been flooding this forum with my problems with the z6 I just swapped in my 88 dx crx. Now that I have the TPS fixed and the computer is throwing no codes at all, I still have some serious lack in power. This is a 125 horse vtec motor that cant get me up a very small incline at 60 in 4th gear in a 2000lb car? And I'm talking very small incline, not a mountain. What gives!? This is worse then when I had the stock d15 in it! I put new plugs, cap and rotor, plug wires, and air filter when I did the swap. I also replaced the fuel filter about a year back. Anyone have any ideas as what to check out?
Old Jan 27, 2010 | 09:18 AM
Default Re: No Power...
no suggestions?
Old Jan 27, 2010 | 09:26 AM
Radim's Avatar
What cam gear are you using, did you correct the timing for the Mini-me?
Old Jan 27, 2010 | 09:36 AM
grog's Avatar
Maybe a restricted exhaust, maybe a clogged catilitic converter.
Is it running rough?
You could check the compression.
Old Jan 27, 2010 | 09:53 AM
I used the cam gear that came with the engine. Its the ZC D16Z6. All I did was take the old belt off and put the new one on the exact same way. I am using the exhaust that was on my car before and it does have a leak where the down pipe meets the cat, I couldn't for the life of me get it to line up right so at the higher rpms you can hear the leak. I would check the compression but I don't have a compression tester. Maybe I'll just do a custom exhaust, I was going to anyway since I am boosting it over the summer. Does anyone know of a d series 4-2-1 header with a 2.5" collector?
Old Jan 27, 2010 | 09:55 AM
Radim's Avatar
My ebay header came with a 2.5" collector.
purplerain11
Jan 1, 2012 09:55 PM
Midori Green
15
Nov 3, 2007 05:16 PM
accordingly
Apr 22, 2004 12:56 PM
abeaujuin
Jul 15, 2003 04:49 AM
blulude92
May 4, 2003 04:05 PM
